comp fail
Old Jun 18, 2015 | 12:09 PM
Weavr99FLHT's Avatar
Weavr99FLHT
I'm skeptical if the comp is actually bad this soon. Maybe the comp bolt needs to be retorqued, or primary chain loose ( tensioner sometimes doesn't ratchet up when needed ). Removal of outer primary can check those ( and chain alignment )
Old Jun 18, 2015 | 12:11 PM
FlaHeatWave's Avatar
FlaHeatWave
A noisy Comp is not life threatening in any way, sometimes embarrassing, yes, life threatening, no...
Old Jun 18, 2015 | 12:55 PM
lionsm13's Avatar
lionsm13
If the OP uses anything that is not certified HD approved it will absolutely void his warranty and it will out of pocket for him if he chooses to go this route.
No question about it.
Old Jun 18, 2015 | 01:05 PM
Fat King's Avatar
Fat King
Originally Posted by Gunnyreed
Just traded my 09 sb in for a brand new 15 rg. After only 1500 miles I'm hearing a noise that sounds like rattling in the front part of my primary. A buddy of mine works at an indi bike shop and said it sounded like the comp. I took it back to dealer and they confirmed that it was the comp but I shouldn't worry because it's under warranty, and just ride it and they'll replace it before then. After reading some post on here I'm a little concerned about this and my safety. Any input would be greatly appreciated.
Are you running syn3 in the primary? If you are dump it and put some formula+ in. Worked for me.
Old Jun 18, 2015 | 01:22 PM
Gunnyreed's Avatar
Gunnyreed
2nd Gear
Yeah that's worse case, however I have read a few older post with guys having there's lock up due to metal stopping the chain.
Old Jun 18, 2015 | 01:24 PM
Gunnyreed's Avatar
Gunnyreed
2nd Gear
I'm running the synthetic Harley brand from dealer, not sure what that is?
Old Jun 18, 2015 | 02:51 PM
goodbirds's Avatar
goodbirds
Lightbulb
Just replaced my compensator at 86,000 miles. Mine is an 07 but the new compensator is improved since my model year. The rattle you're hearing is likely a tensioner problem, or like someone else said, the compensator bolt needs re-torqueing.
I run HD 360 in the primary, but Syn 3 in engine and transmission.
Old Jun 18, 2015 | 03:04 PM
msocko3's Avatar
msocko3
Sounds like Syn3, I'd put some Formula+ in it and see if it helps.
Old Jun 18, 2015 | 06:02 PM
hardheaded's Avatar
hardheaded
mine made noise from new and got worse and worse with more miles. by the time it had four thousand miles on it , it was rattleing like crazy. junk from the start. i installed the baker attitude primary chain adjuster and it help, but when it got hot and at cruise speed it was still hammering itself to death.
Old Jun 19, 2015 | 06:06 AM
msocko3's Avatar
msocko3
The shitty compensator from Harley is a mixed bag. Some last and some die a very early death. Harley should be ashamed of it self for that crummy design. Its looking like Baker is on to the ticket with their new compensator.
moosehunter22
Sep 4, 2015 11:50 PM
kzad
Aug 25, 2011 07:50 AM
BassCatcher
Oct 5, 2009 11:29 PM
Sammi
Sep 21, 2009 04:18 PM
28gauge
Jul 8, 2009 09:19 PM
