SuperShox
If a shock has 3" of travel, and you want to set the sag at 30-33% of total travel, wouldn't you have to measure along the angle of the shock? That's where you know there is 3" of travel.....
If you measure from the axle to the fender strut, to adjust sag, you would first have to find out the total travel of the axle to strut. Wouldn't the shock angle affect the maximum distance axle to strut?
In any case, it would still be directly proportional, or equal to, the 3" of the maximum shock travel....
It seems it would be easier to just measure the shock from center to center, top to top, or bottom to bottom....
What am I missing here...
So you are saying total travel of 3 inches is what the shock travels. That would also mean that total axle/wheel travel would be more then 3 inches because shock is mounted at an angle and between axle and pivot point. I believe total travel of 3" is total axle/wheel travel. Unless you install taller/longer shocks. This is what I do. I lift bike to measure full travel. Then adjust preload for sag of ~30%.
It is not really difficult. I measured my unloaded shock travel length with my bike on the jack, easier if you are by yourself. Explained by Progressive, applies to all shocks.
BTW Sky, what's the latest on your shock review?
https://www.youtube.com/watch?v=3kjuirr89jQ
Curious too. These were supposed to be the Ohlins killers... so I held off buying Ohlins.
Think I need to give Howard a call.
