Wanting to upgrade my air cleaner for my 15 RGS. Is there a filter other than the screaming eagle thats fits with the stock a/c cover? I had an open a/c on my previous dyna and it would bog down in any real rain. Any recommendations?
I have k&n in stock housing but cut two more openings in the back plate. One above the original & another on the bottom. Works great looks stock & most of all for me it don't stick out.
Arlen Ness 18-441. The best price I found was from Phat Performance.
Do you already have a tuner? Changing mufflers and air cleaner you should get a tuner to flash a new map to the ECM.
Good luck
I checked with an arlen ness dealer, they told me the big sucker doesn't work with the stock cover. I really have a soft spot for the S&S tear drop, but not sure if I will get good enough air flow with that, especially since I am wanting to upgrade my cams.
big sucker can use the stock football cover while the derby cover I would need to purchase a cover . I do like the naked air cleaner look with cover , but I may stick with willie g cover Im currently using
You will get plenty of air flow with the tear drop.
OP look at zippers performance they have a kit that will utilize the stock cover.
