2009-2015 Harley Touring Boss Fat Cat 2:1
Old Jul 2, 2015 | 02:56 PM
canyon-electra's Avatar
canyon-electra
Default 2009-2015 Harley Touring Boss Fat Cat 2:1
will a 2009-2015 Harley Touring Boss Fat Cat 2:1 fit 2006 Touring?
What if I remove the mounting bracket under the transmission?
Old Jul 2, 2015 | 05:13 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
No it will not, even if you remove the transmission bracket.
Old Jul 2, 2015 | 10:32 PM
Mathnerd's Avatar
Mathnerd
Not meaning to argue but why not? The only thing I can think that would be different would be the size and location of the O2 sensors. It should physically bolt up though.
Old Jul 3, 2015 | 02:32 AM
OldEnuf2NoBtr
The frames along with the mounting points are different on the two model years. That's why they make two different exhausts. One for pre-09 models and one for post-09's. If you have the capabilities to fabricate things, by all means take a stab at making it fit.
Old Jul 3, 2015 | 11:24 AM
Mathnerd's Avatar
Mathnerd
The only mounting points are the heads, the trains trap door and the bag support. The mount on the trap door is a bolt on and the bag support is the same on all the twin cams. The only issue is going to be the O2 sensor size and location and any muffler shop can fix that.
Old Jul 3, 2015 | 12:27 PM
slothy's Avatar
slothy
if its a newer fat cat they have both bung sizes
Old Jul 3, 2015 | 01:25 PM
aclass's Avatar
aclass
D&D changed the fat cat to match the frame change in 09. The newer header has the curve to accommodate the wider rear end.
VDeuce
Touring Parts
Jun 26, 2017 09:33 AM
heavywear
Touring Parts
Mar 14, 2016 11:04 AM
Gliden
Dec 13, 2014 03:07 PM
flea402
Oct 27, 2010 12:30 PM
