Vibration problem
Old Jul 4, 2015 | 07:18 PM
harleyflo's Avatar
harleyflo
Default Vibration problem,primary or transmission
Got vibration when i release the throttle at 2800 to 2200 rpm.If i pull the clutch vibration goes away in that rpm range.Vibration comes from under the floorboards right to under the seat.That started about 150 miles ago.At first i tought it was my new front tire but when i pull the clutch the vibration stops.Any clue?
Old Jul 5, 2015 | 08:28 PM
whetsel.m's Avatar
whetsel.m
Inner primary bearing
Old Jul 5, 2015 | 11:16 PM
user 8373900's Avatar
user 8373900
Check your motor mounts and give the exhaust a look where it passes by the floorboard, sometimes they will hit there. The inner primary bearing makes itself well known with a tel tale sound.
Mark
Old Jul 6, 2015 | 12:12 AM
whetsel.m's Avatar
whetsel.m
If it was a loose mount it would vibrate all the time, not just with clutch use.
Old Jul 6, 2015 | 12:48 PM
hellbilly78's Avatar
hellbilly78
Motor mounts or exhaust as noted. Also ive read guys say this can happen if you have a cross under pipe and the bolt that holds it up is loose. As it bolts into the bottom of the trans. And the reason it goes away with the clutch would its dropping the rpm down and no strain on the motor at all.
Old Jul 6, 2015 | 08:37 PM
harleyflo's Avatar
harleyflo
ok guys i need to know were the motor mount are.
Old Jul 7, 2015 | 08:14 AM
hellbilly78
Is that a serious question?
Old Jul 7, 2015 | 08:22 AM
Jackie Paper's Avatar
Jackie Paper
Of course all questions are serious.....they are bolted to the motor and extend to the frame..That inner primary sure gets throw out a lot ..
Have not a clue to your problem but to try to answer your question......Watch motor closely when someone starts, idling and turns it off looking from the side.
Does it rock fwd or back excessive almost like it's bouncing? It's normal to move but it should be like rubber damping it. My friend's Roadking front motor mount bolt fell completely out. Probably from someone not putting it in correctly however.. There is one in front below oil filter. One hanging under gas tank above horn cowbell . Other is at rear transmission. On your bike, the engine,transmission, rear swingarm and wheel are a whole assembly bolted to the frame as a unit bound by the rear shocks.
Go to this site and search the engine mounts with stabilizer..There is some elaborate mounts on your bike. Never did find the transmission mount but it's there. Would appear if someone has messed with floor boards, that front mount could be loose since it bolts to the hanger for it.
http://partsfinder.onlinemicrofiche....T-GLIDE%AE-(PZ)
Old Jul 7, 2015 | 08:27 AM
hellbilly78
I thought maybe he was just bein a smarta$$ haha. Im no motorcycle master mechanic by any means and not tryin to be a dick but i figured its kind of common sense what a motor mount is.
Old Jul 7, 2015 | 10:05 AM
Jackie Paper
RIP thought harleyflo was being a girl..
