Oil seeping out from under bolt by sparkplug wire??
Old Jul 24, 2015 | 09:35 AM
Jackie Paper's Avatar
Jackie Paper
Do not check torque. I know they torqued it probably with a machine but the call out is so much torque and then a degree turn. If it's really the torque, you need to start over. That is very typical of assembly lube. Of course point it out if it comes back but I would clean it up a couple times first. If you complain too early, the kid who worked at Mickey Dee's last year may work on it. Been dozens of post on here on new bikes doing that.
Old Jul 24, 2015 | 07:54 PM
northeastconfederate's Avatar
Originally Posted by Weavr99FLHT
The head bolt attaches to the cylinder stud. The cylinder stud passes thru the cylinder, thru the head gasket, into the head. Entirely possible that a seep at the head gasket can result in oil traveling along the stud to the bolt. Most likely not the case but instead assembly lube is working its way up the stud and seeping out the bolt.
Nope. Take one apart some time and take a look at where the cylinder studs are and where the oil returns are. The only oil that can get on the cylinder studs if nothing's cracked or otherwise F-ed up is the oil used to lube the threads and the bolt heads during assembly.
harley8963
Engine Mechanical Topics
Jun 30, 2019 01:24 PM
MikeSz
Jul 1, 2013 10:20 AM
jbrady5979
Aug 7, 2011 02:51 PM
OHOGO
Jul 22, 2008 06:06 PM
jeepster09
Product Reviews
Jun 20, 2006 11:58 PM
