slip ons?
Old Jul 24, 2015 | 08:46 AM
gipper's Avatar
gipper
Originally Posted by jt metal
Gipper, you're thinking 4" is a good compromise? I took a peek at those supertrapp stouts.
Right now owning the h.d. screaming eagles....I think their 3.5"
Based on what you've told me online and "offline", yes, I think 4" is exactly that, a compromise. It's a good one, if that's what you want. If so, it then comes down to who's 4" slipon you go with, and I am not EVEN going to open that can of worms! There's more than one good one to choose from, that's for sure.
Old Jul 24, 2015 | 09:56 AM
jt metal's Avatar
jt metal
Shoot, buddy!
On the short list is supertrapp stouts. Which I see no one runs.....
Keep in mind I have a stock head pipe with converter removed. They say the stock head pipe is good up to 100h/p then it's time to start looking.
Quality look/chrome is Vidal. Sound is subjective.
Old Jul 24, 2015 | 10:17 AM
gipper's Avatar
gipper
Shoot, buddy!
I have no experience with gutted headers, but Harley chrome is pretty tough to beat, and I see nothing wrong with the look of Harley headers. With your current set up, my guess is that you'll be close to 100 HP, +/- a few. Your HP might even be a little higher than your torque with the cams that you have, but I'm only guessing on that one.
Old Jul 24, 2015 | 10:19 AM
jt metal's Avatar
jt metal
Nice way to bypass the question, gipper.....hahaha.
I see a set of jackpots for sale on the forum. I better move fast........
Old Jul 24, 2015 | 10:51 AM
SBates08's Avatar
SBates08
Nice way to bypass the question, gipper.....hahaha. I see a set of jackpots for sale on the forum. I better move fast........
Just go ahead and get a 2-1. That's what your gonna end up with anyway. With Kutter HD's discount I got my V&H ProPipe for $520.
2010 Limited with some stuff
Old Jul 24, 2015 | 11:26 AM
gipper's Avatar
gipper
I didn't see a question mark, there buddy!
I don't have any experience with Jackpot slipons, but I have to believe that they're quality. I haven't read anything stating otherwise.
Old Jul 24, 2015 | 11:41 AM
gipper's Avatar
gipper
You're probably close to being right, Bates, but jt has got to figure out what he wants when and if he finds out that what he has is no longer fitting the bill. Happened to me. I liked the looks of my 4.5" High Outputs, and I also liked the top end that they gave me, but after three years of having anemic torque levels, I realized that I didn't have the right combo for my taste, which had changed over time. I don't regret what I did initially because I would never have known for sure had I not gone the direction that I had. Bottom line is that education costs money!
jt, hopefully you'll continue to prefer mid to top end performance rather than low end torque; it'll save you money. I'm not interesting in betting on that premise, but if I were, I'd bet that down the road you'll start wishing you had more on the bottom end where you'll tap into that every time you ride. You probably won't tap into your top end performance level every time you ride unless you're building a one mile strip drag racing bike. You'll have what you need in that case.
Old Jul 24, 2015 | 11:56 AM
jt metal's Avatar
jt metal
Gipper......this whole setup is a bandaid done on a budget. Less than $2g into it. Might be close to 100. Probably more like low 90's as fas as h/p.
Tuner, cam, used slip ons, open a/c, hollowed cat....... Going to step into suspension and 23" wheel. Then either a turbo or stage 4????? I really like the Trask product. Don't know inherent problems in the heat. Need to research more.
Not interested in buying too much more. Until I figure out what to do. Shooting for being content. Not easy....
Old Jul 24, 2015 | 12:05 PM
GEORGEW's Avatar
GEORGEW
Roger that, jt. Think of slipons much like you would cams....you can't have your cake and eat it too. The smaller the diameter, the more back pressure your engine gets, which equates to more torque. That said, you lose HP on the top end. The bigger you go, the less torque you have, but the more HP you gain on the top end, up to "that point of diminishing returns", wherever that may be based on your set up.
Based on our conversation earlier today, you're happy with your cams which are mid range to top end cams. If you want to maximize those cams, you'll choose slipons that are 4" to 4.5", most likely. You'll have a 103" that'll easily do 120 MPH, and still be making solid power when you roll on the throttle cruising at 85-90 MPH, and likely even higher. If you want to balance those cams out a tad, you might go with 3.5" slipons that are going to increase your torque range a touch, give you excellent mid range, and respectable top end (HP). But the top end with 3.5" won't be the same as it would be if you went with a larger diameter slipon. If on the other hand you wanted "off the line, hold on for a good time" bottom end torque, you're current cams would not be the right choice for that. You would want to choose a cam that makes power in the low RPM range, AND couple that with 3.5" slipons.
For whatever it's worth to you, I don't think that the 103" puts out enough power to really support a 4.5" slipon IF torque is the goal. I ran a set for three years until I dropped down to a 3.5" last weekend. The difference in torque is remarkable with the 3.5" slipons. BUT......before changing to 3.5" slipons, I could roll the throttle at 90-100 MPH, and the power that my motor was still making at that speed and RPM level was astonishing (118+ MPH was no problem, and I don't have a top end cam in my bike with the TW-222's). I just decided that that was not where I wanted my power band to be. Stuff can go very wrong very fast at those speeds, so I would rarely go there for that reason.
Comes down to what you want, but they can be viewed through the same lens (essentially) that you view cams through: you can have one or the other (or something right in the middle), but you can't have both or all three at the same time.
The size of the Muffler (3.5" 4" or 4.5") has ABSOLUTELY NOTHING to do with Performance ..
Its the Baffle that dictates the Performance.... As soon as jt sends me an email I can prove it!!
Old Jul 24, 2015 | 12:27 PM
gipper's Avatar
gipper
George: I don't disagree with you. I bought quiet baffles for my 4.5" slipons, and while it gave me more back pressure, changing the torque level, it also changed the sound such that I wasn't happy at all. It was also ugly as it was completely visible from the back end. That's just my experience.
You're right in your statement, but there's more to the equation to consider than just a baffle. It also begs the rhetorical question: why buy a larger diameter slipon just to choke it down with baffles, unless of course the desire IS a tuneable slip on whereby the baffles can be removed and replaced as desired?
There's more than one way to skin the "torque cat", but we're just talking in general terms, and generally speaking guys choose a smaller diameter slipon with a smaller baffle than the baffle generally found in a 4.5" if increased torque is the goal.
You're not wrong, generally speaking; nothing to prove here. I would ask you this though....if you took baffles completely out of the equation AND the slipons, would you make the argument that there would be no performance difference between a 3.5" and a 4.5" "pipe"? Hmmmm.....
