Hayden Primary Tensioner
Old Jul 24, 2015 | 03:37 PM
sanman4ever's Avatar
sanman4ever
Default Hayden Primary Tensioner
Originally Posted by qtrracer
Works perfect in my 08. Been in for 2 years.
Exactly as I explained. You have an 08 so your fine 09+ not a good idea.
Originally Posted by nytryder
The Hayden Tensioner is a piece of **** imo. Customer support is useless. Mine took out most of the primary components. All the while Hayden support is telling me not to worry. Keep the stock HD piece.
I didn't want to be this harsh but since you've opened the door you're right. There's tons of threads on it it's a total piece of junk.
Old Jul 24, 2015 | 08:45 PM
propflux01's Avatar
propflux01
Some of the '09's (like mine) still had the '06A Compensator. As long as that one is on there the Hayden will give you the 3/8" gap between the shoe and the bracket. The later Compensators were slightly larger and reduced the gap to 1/4" and started the issues referred to in past threads.
Old Jul 24, 2015 | 09:05 PM
shaker's Avatar
shaker
I installed mine 3 years ago and it works perfectly. Don't know why a lot of you are having problems. Mine installed exactly to specs without shimming. Of course I did the work myself so I didn't rely on the stealer to say its all setup right. Has been functioning great without much wear.
Old Jul 24, 2015 | 09:22 PM
hattitude's Avatar
hattitude
You have an '07....
Read the post right above yours for the answer...
Old Jul 24, 2015 | 09:49 PM
CGLTD's Avatar
CGLTD
I installed the baker attitude and it it's perfectly quiet in the primary. Read reviews on the Hayden and went with the Baker. Just know that it's a manual adjuster which I'm fine with. My chain was always very tight with the stock adjuster
Old Jul 25, 2015 | 06:44 AM
shaker's Avatar
shaker
You have an '07....
I also installed the screaming eagle compensator at the same time. So I don't have the original stock one.
Old Jul 25, 2015 | 06:54 AM
hullhorr's Avatar
hullhorr
The old ones were a little too tight because of the springs. The newer ones work great. The trouble with the stock tensioner is it only gets tighter, and will not loosen up.
Old Jul 25, 2015 | 08:36 AM
NELS's Avatar
NELS
'10 RK insralled the Hayden a couple of years ago cause the stock tensioner was too tight . No problems now !
Old Jul 25, 2015 | 08:49 AM
B18cx's Avatar
B18cx
08 here with the SE compensator. Tried the origional Hayden spring set up and there new revised spring set up. Both had the same outcome that led to the chain slap issues stated before and the "thats close enuff" response from tech support.
Old Jul 25, 2015 | 09:47 AM
hattitude's Avatar
hattitude
Sorry, I missed that.
I have a '12 Limited. I thought I'd get a Hayden as a preventative measure since I read the OEM can over tighten the chain.
I had a Hayden with with the new springs, and the chain seemed way too tight.... I didn't even button up the primary. I took it right out.
The OEM was fine when I removed it, so I put it back in.
If I do anything in the primary in the future, I'll go with Baker components.....
