surging and backfiring
Old Jul 29, 2015 | 07:10 PM
fishtale's Avatar
fishtale
To be fare to them, I was on a trip and it was close to closing time and they did a quick check for me. They are not my local dealer.
Old Jul 29, 2015 | 08:24 PM
hdultra2010's Avatar
hdultra2010
it could be just bad gas i guess, put some seafoam and ride for another new full tank of gas. if it just started and it was good before no mod made.
also reach behind the intake for map sensor it may get loose. find mine loose after it was doing the same thing . mine was intermittent .
Old Jul 29, 2015 | 09:22 PM
Retrop's Avatar
Retrop
I see. Well, I would start with the fuel pump which is inside the gas tank. I note that you mention that the problem started after you filled up with gasoline. You could very well have a plugged or restricted filter which is restricting flow at lower rpm or you might (less likely) have a cracked fuel pump (they are made of plastic). The fuel filters are commonly replaced and they are about $17.00 or so.
Old Jul 29, 2015 | 09:42 PM
mmats69's Avatar
mmats69
Also check the plug on the throttle body. Could have bad throttle pins. Put some dielectric grease on it and see what happens.
Old Jul 30, 2015 | 12:42 AM
hd_rolling's Avatar
hd_rolling
With just stage one add ons I'd disconnect the tuner and see if it runs any better, at least you would be able to cross it off the list of possible issues.
When I was running my first PCV years ago it did the same thing, pulled it and the bike ran great. Fuel moto replaced it and all was well, decided not to use a piggy back tuner any more and sold it so I could get the power vision.
Old Jul 30, 2015 | 05:35 AM
fishtale's Avatar
fishtale
Thank you folks for the suggestions
Old Jul 30, 2015 | 06:18 AM
chief08's Avatar
chief08
is it under warranty? take to dealer let them check it
Old Jul 30, 2015 | 06:38 AM
Weavr99FLHT's Avatar
Weavr99FLHT
Default surging and backfiring
In addition to what has been said, Look on top of the induction module, behind the air cleaner, use a flashlight. There is what looks like a hose fitting (purge tube) that should have a rubber cap on it. If that rubber cap falls off, which I have seen before, will have symptoms you describe but usually bike will throw a code. Rubber caps can be bought at autozone.
Old Jul 30, 2015 | 09:42 AM
Smittyjf's Avatar
Smittyjf
This was my first guess
Old Aug 10, 2015 | 10:04 AM
fishtale's Avatar
fishtale
UPDATE: The problem turned out to be bad gas. After a couple of fresh tanks and some Sea Foam the engine smoothed right out.
Thank everyone for the replies.
