Sturgis Trip - Fuel Problems
Old Aug 9, 2015 | 05:26 PM
Pix's Avatar
Pix
Our friends BMW would not stay running until it got warmed up, once they got to Jackson hole no more problems
Old Aug 9, 2015 | 05:30 PM
shooter5074's Avatar
shooter5074
From: Western Illinois, land of bad roads, and corrupt politicians
Originally Posted by RollaMo
Rode all over the Sturgis area (Rapid City, Devils Tower, Mt Rushmore, Badlands, Spearfish, Deadwood, etc) a week ago, and didn't have any fuel issues.
Same here. No problems with gas this year.
Old Aug 9, 2015 | 05:32 PM
ToppDogg's Avatar
ToppDogg
Runs fine for a while after you stop, so it cools down a bit, my guess is your taking in some air in that line and its not bad fuel. bottle of soapy water is an easy tool to locate that one.
Old Aug 9, 2015 | 06:01 PM
KW-HD Rider's Avatar
KW-HD Rider
We ran all over the area last week with no problems. Did 5500 miles over the course of 2 weeks and had good luck with fuel except 1 small station in the middle of nowhere Kansas that only had 87 regular. With a million bikes in the area it might not be usual for a few fuel pumps go bad.
Old Aug 9, 2015 | 06:37 PM
jaxdwg's Avatar
jaxdwg
I try to fill up in a high volume area because they get a fresh load of gas every few days. That country store is not usually the place to get fueled up, unless you have to-- I used to have a station😐
Old Aug 9, 2015 | 07:23 PM
bigskyroadglide's Avatar
bigskyroadglide
Just got back from Sturgis. 800 plus miles out 3800 miles there and 800 plus miles back.
Only fuel issue was when i let the tank get low enough for the light to come on. Sputtering at high speed. Once filled up problem went away.
Heat and low fuel levels could be a cause
Old Aug 9, 2015 | 08:15 PM
btsom's Avatar
btsom
How many miles and how old is your fuel filter. Just replaced mine at 25,000 miles and was amazed at how dirty it was. Could be some extra ethanol picked up some extra dirt and gunked up your filter. Was the fuel pump pressure check static or with the engine running?
Old Aug 10, 2015 | 08:55 PM
Jerry1834's Avatar
Jerry1834
What year bike ----2009 and 2010 are having fuel induction module problems - just like you described - first they thought it was the plug but turns out it the module only thing you have to replace the whole unit not just a module.
Old Aug 10, 2015 | 09:09 PM
lh4x4's Avatar
lh4x4
There may be another cause. The elevation in the Hills and Wyoming is between 4 and 6 thousand feet so there is about a 20 percent drop in available oxygen.
The net effect is the bike will seem to be running rich. The answer is run lower octane which will burn more fully and run smoother.
E10 had nothing to do with it or any of the stations were you filled up.
Old Aug 11, 2015 | 03:48 PM
Jerry1834's Avatar
Jerry1834
I have run higher elevations (10.5) and never had a gas problem. Would run 89 - 93 and was never an issue out west.
