Fork oil
Old Aug 14, 2015 | 11:10 AM
trunomad's Avatar
trunomad
Default Fork oil
My front suspension seems soft 2008 ultra 20k miles. Think fork rebuild is needed?
Old Aug 14, 2015 | 11:12 AM
Spur56's Avatar
Spur56
Drain oil. Replace with Mobil 1 ATF. Problem solved
Old Aug 14, 2015 | 11:27 AM
SBates08's Avatar
SBates08
Changing fork oil isn't hard to do at all and it will more than likely cute your problems. There's several threads on here explaining how it's done. I use either Spectro or BelRay 10wt fork oil in mine. I've never used the ATF but it should work well too.
2010 Limited with some stuff
Old Aug 14, 2015 | 12:20 PM
smithbrl's Avatar
smithbrl
This is the thread I used as a guide when I changed my fork oil. His blow by blow is at post #23. It worked out fine for me.
https://www.hdforums.com/forum/touri...il-change.html
Old Aug 14, 2015 | 04:53 PM
trunomad's Avatar
trunomad
Default fork oil
thanks for the info (post #23).I'm going to change oil Sunday.Also install throttlepak
Norms 427
Sep 17, 2014 08:18 PM
jimbo285
EVO
May 7, 2014 11:09 AM
samabb1
Feb 6, 2012 08:00 PM
warbisjohn
Apr 24, 2011 08:35 PM
CKS
Sep 28, 2010 01:41 AM
