Front suspension upgrade
Old May 11, 2017 | 02:00 PM
grbrown's Avatar
grbrown
Wink
Originally Posted by oricko
For those of you that switched to the Progressive cartridge, did you change or replace other seals in the forks. I am thinking of installing these in my 06 Ultra and would like to have everything I need before starting the job.
I've installed Ohlins cartridges, but replaced everything in the way of seals and bushings when rebuilding my forks. You may be surprised how dirty they are inside, if you strip and clean them first.
Old May 11, 2017 | 04:44 PM
GLW Mike's Avatar
GLW Mike
Speaking of it....my Progressive FST mono tube for my 16 Limited was delivered today from DK Customs. Bitubo shocks delivering tomorrow.
I don't have any experience on those cartridges, so I will have post my thoughts after I get them on and ride.
Old May 11, 2017 | 06:10 PM
RockyMtnRG's Avatar
RockyMtnRG
Default Traxxion Dynamics
Originally Posted by ottomatics
I was riding on 26s south from Johnson City to Asheville, and entered a curve from the left lane doing 60. I ended up in the right lane after hitting some choppy pavement, needless to say, out of control. Second incident. Blood mountain Georgia, arriving from the north. As I was approaching the summit I leaned into a left turn but the bike 2014 FLHTK (with 44,000 on the odometer) had different ideas and drifted right. Thankfully the ABS brakes functioned properly and I was able to stop quickly before running off into the trees.
At this point I started looking for a solution to the suspension quirks before it killed me. I live in Roswell Georgia - next town over is Woodstock, GA and if you don't know where I'm heading yet, it's Traxxion Dynamics.
There are certainly less expensive solutions available, but I didn't want to screw around with a suspension that could possibly save my life, vs. experimenting with less expensive alternatives. Do it right the first time and save yourself from having to replace it.
I've only put about 500 miles on the new suspension AK-20's and Bitubo rears, dbut I find myself looking for all the bumps to see how the new setup performs. The bike is completely different, completely tight around turns with no front end dive during braking.
When my better half is riding shotgun, she's ready to kill me when we hit a back breaker without warning. So far no complaints.
Here's a second vote for the Traxxion Dynamics. I tried the Progressive Monotubes on my 2012 FLTRX with both Progressive and Ohlins rear suspension. The AK-20s and Bitubo rears are by far the best combination (in fairness, the AK-20's up front probably go a long way toward making the rears seem so much better).
The Traxxion are certainly not cheap, but are well worth the money IMHO. I was ready to trade-in the bike for a Victory, solely to get a decent suspension, before I found the AK-20's.
Also, here's some good info on front suspension from DK Customs (they didn't carry the AK-20's when I bought mine a few years ago, but looks like they came to the same conclusion about them performing the best) --
http://www.dkcustomproducts.com/DK-C...S-TST-RP-I.htm
Old May 11, 2017 | 06:45 PM
MatteGlide15's Avatar
MatteGlide15
Running Legend Axeo front end kit for my 15RGS
Old May 11, 2017 | 07:29 PM
buell95's Avatar
buell95
Default Front
Mine is almost done.
Attached Thumbnails Front suspension upgrade-am2.jpg   Front suspension upgrade-am3.jpg
Old May 11, 2017 | 10:35 PM
wscott's Avatar
wscott
[QUOTE=fordhd2005;14309206]I changed the fluid and used a 50/50 mix of Type E and SE... I don't have any complaints...[/QUOTE
Agree,he should 1st try a couple diff mix's of fork oils because he may find that alone may be enough to satisfy him costing only a few bucks for fork oil if he does oil swap himself.
But if trying diff fork oil mix doesnt satisfy him then it's time to think about spending significant bucks,time & effort required to upgrade the front suspension @ that point.
It seems more then just a few guys are happy with improvement they get from doing fork oil swap and i am once of them for sure though i am currently in the process of dialing in front fork oil mix to get just the ride/handling perf i am looking for which is diff for every person out there.
I 1st tried going to 100% SE HVY WT FORK OIL and bike handled considerably better with almost no more fork dive when braking which i went with for past 10k miles or so.
But it was a bit stiff feeling and once in a while when hitting a lrg bump the tire would actually leave the road surface fror a spkit second which isnt good.
So with that in mind for safety sake just yesterday i drained the hvy fork oil and installed a mix of 8oz se hvy fork oil & 2.8-3oz HD type E fork oil in each fork tube of my 09 flhtcu to see how that does.
I hope this new mix thinned out the fork oil just enough to remove the sharp edge of stiffness so the front wheel doesnt leave the ground on lrg bumps and dont feel every little crack or abnormality on road surface too.
I choose to not go with a 50/50 because the stock all type E fork oil setup was so mushy i thought it would be a bit on the light/too thin side going back to more fork dive when braking etc.
I hope the current mix i just installed does the trick but if its still a bit too firm and front tire still leaves the road surface at times when hitting lr bumps the fork oil is easy to change on my 09 FLHTCU so i can drain current oil and install a 50/50 mix like you did to see how that does,takes me appox 1hr to do.
Cant wait to try out my the 70% SE HV & 30% HD type E fork oil mix sometime next wk because weather here in upstate NY currently sucks but is forecast to finally improve getting out of 50's that are supposed to be 70+ deg!/YAHOO!!!
Happy motoring.
Scott
Old May 12, 2017 | 03:56 AM
grbrown's Avatar
grbrown
Thumbs up
WOW! You perisher! Jolly well done, now show off the rest of your bike. I have Ohlins cartridges and shocks, but nothing quite so sophisticated or up-market.
Old May 12, 2017 | 06:52 AM
Twinrider's Avatar
Twinrider
I put the HD hand adjustable premium shocks on the back and HD's duel fork cartridge kit up front. Really improves the ride and great bang for the buck.
Old May 12, 2017 | 08:53 AM
jefla's Avatar
jefla
buel95, please give us details of that sweet front end.
(Although one of my best buds is a Brit, I had to look up "perisher.")
Old May 12, 2017 | 08:57 AM
grbrown's Avatar
grbrown
Thumbs up
Well done - I wrote that without thinking!
