Need help with ABS bracket + Performance Machine lowers.
Hi All,
I'm just tying up the installation of a set of Ohlins cartridges and PM chrome lowers. The only snag I've run into is the ABS bracket doesn't fit nicely. I'm sure the judicious use of a grinder would help it fit but before I do that I wanted to see if anyone else has found a more elegant solution.
