Ok Help
1 Hands Free with the FOB
2: Using the pin
31313 is the code HD puts in the bike at the factory. If the previous owner didn't change it you may be in luck.
If he did change it A HD Shop may be able to read the PIN with the DigiTech.
Do your FOBs have buttons? Next to the bike push the button twice quickly to disarm the system.
In the troubleshooting section it say's if the fobs button has been pressed numerous times it may fall out of sync with the TSSM. If this happens press and hold the fob button for 10 -15 seconds until the security system responds with 2 turn signal flashes.
Good Luck
Good Luck
but all is not lost. first try the simple stuff, replace your batteries. and make sure that they are put in the fob oriented correctly. very common to put them in upside down.
if the security recognizes the fob and allows you to start the bike, then you'll be able to retrieve and reset your code. to do this:
turn your ignition on-off-on-off-on
immediately press left turn signal 2x
then right turn signal once
your existing code will now be displayed in the odometer window. to change it, just cycle through the digits 1-9 using your left turn signal switch, and enter it with your right. once you've changed all the numbers, just turn the ignition off.
Just trying to help
the button fobs referenced are the tssm, which are hdi versions. the hfsm (hands free security module) is the domestic version. I didn't know that they still used the button fobs (though I didn't really even think about it), learn something new everyday
I did take the fob into the house and checked starting with just the pin number. It worked whoo hoo
