What do you have hooked up to your accessory switch
12v power port in tourpak plugged into the acc plug but not activated by the dash switch. Plug on pre 14s is a 4 wire plug
ground
on with ignition
on with acc switch
on with brake
My power port is wired to ground and on-with-ignition. I've seen someone install spot lights and use the acc plug and wired them to on-with-brake then couldn't figure out why forward facing lights came on when they touched the brakes.
ground
on with ignition
on with acc switch
on with brake
