Belt damage... not your average question.
Old Aug 29, 2015 | 09:17 PM
HardRider1's Avatar
HardRider1
Originally Posted by Imold
Down into the chord, and looks like about 20% of the width of the teeth is gone.
You do realize that you are looking at the outside of the belt? No teeth shown here, run it til it fails or replace your call
Old Aug 29, 2015 | 09:24 PM
Ytcoinshooter's Avatar
Ytcoinshooter
Well it's not the business side of the belt so I'm sure you've got some time & miles. I went 7000 miles on a belt that had a small hole in it from a sharp object that caught between the pulley and belt, dug into the belt and worked its way in enough to fully pierce the belt. I always checked my tires and belt daily and remember pulling out the sharp rocklike object. It was so sharp and irregular I was sure it wasn't metal. This was a Gates Polychain / Supermax rear belt conversion we did on my '79 shovel in 1982. Fortunately the material used in the pully face was undamaged, just belt took it.
I'd be all crazy in your case trying to figure out where that bolt came from to be lodged as it was. Also any residual damage from the bolt to anything else besides the belt...?You said you didn't see anything it may have come from. Still you were inside your primary to fix a leak. I'd be second guessing myself and have look-see inside the primary.
I love how tough the belts are. I used to get a lot of jokes directed at me WAY back then as the "rubber band man" for having primary & secondary belt drive conversions. The original Sturgis model was a new novelty back then.
Old Aug 29, 2015 | 09:58 PM
JimTJr's Avatar
JimTJr
I lay the bike on its side and check.
Am I the only one who noticed that part of the paragraph? LOL..... I could think of better ways to inspect my drive belt....
Old Aug 30, 2015 | 01:04 AM
Bluehighways's Avatar
Bluehighways
I'd take it easy on it. Then, in the not to distant future, I'd replace it at a time and location of my choosing. For what is really a fairly simple part . . . there's an awful lot of stuff that has to come off the bike to replace it. Not something I'd want to be forced to do a long way from home . . . even if I could lay the bike on its side to work on it.
Old Aug 30, 2015 | 01:44 AM
Imold's Avatar
Imold
Got me, can't believe I didn't catch that. I'll blame it on being so tired from cleaning out the shed...
Old Aug 30, 2015 | 07:04 AM
jefla's Avatar
jefla
Seems you're going to replace it someday. After it breaks, after you grow tired of fretting over it, or before you sell the bike. Do it now on your terms.
Old Aug 30, 2015 | 07:09 AM
Stiggy's Avatar
Stiggy
Every time you ride out you risk a belt break, small chance though that might be. If it was a 15 minute replacement I'd do it. Since its not, I'd ride it til it breaks (at 80,000 miles or so )
Old Aug 30, 2015 | 07:42 AM
goldie's Avatar
goldie
Hi all,
I had a similar thing happen with a small piece of gravel lodged in my belt guard. I had one mechanic tell me he wouldn't ride it a mile, that was 55,000 miles ago. Your gouge is slightly wider than mine. YMMV.....goldie
Old Aug 30, 2015 | 07:52 AM
tesnevo's Avatar
tesnevo
I'd have to replace it just for peace of mind.
Old Aug 30, 2015 | 08:33 AM
hardheaded's Avatar
hardheaded
i would replace it. better to do at home in your garage than on the side of the road.
