Do you do your own servicing?
Old Sep 2, 2015 | 08:09 AM
TheGrandPoohBah's Avatar
TheGrandPoohBah
I do my own service on all my vehicles.
Once while having a rear wheel replaced under tire and wheel coverage, I asked a mechanic at the dealer I trust to do a critical fastener check. He found a couple of small things and we discussed it, as well as His recommendations on things to look out for. I found that very helpful.
I actually look forward to ALL my 5K services. And, do your best on Pre Ride Checks, and ride with confidence!
Old Sep 2, 2015 | 08:29 AM
Coastal CVO's Avatar
Coastal CVO
All of my bikes have never returned to a dealer for service until I bought the Harley. With the way things started off, every scheduled check was a trip to the dealer and every suggestion with the exception of me purchasing a SERT so they could tune the bike was followed. I even went as far as having a statement added to the settlement doc stating the my warranty would not be voided by using a SERT. H-D (MoCo) has a full compliment of lawyers and they used several against me.
The bike is now out of warranty and I service it myself.
Old Sep 2, 2015 | 08:43 AM
LQQK_OUT's Avatar
LQQK_OUT
Default I can fix it
My old man is a television repairman, he's got this ultimate set of tools. I can fix it.
Old Sep 2, 2015 | 09:30 AM
jaxdwg's Avatar
jaxdwg
ASE master tech., A&P, own a shop and have over $100k in tools-- yep. I do my own maintenance and mods. And I either buy or make my own special tools in order to do it correctly. I do use the dealer when warranty is involved. If you don't know what you are doing though, let someone who does, do it. Screw-ups can get very costly.
Old Sep 2, 2015 | 09:42 AM
Bingee's Avatar
Bingee
As time goes on HD is adding more and more stuff that requires the Digital Technician diagnostic system to service or check out. That needs to change. HD needs to provide owner access to that system for normal maintenance procedures like changing brake fluid on a bike with ABS brakes. It could easily be done via a PC and cable.
Old Sep 2, 2015 | 09:49 AM
Melman's Avatar
Melman
The newer bikes have very little "adjustments" available so the 1,000 mile service is basically changing of the fluids for $500.00. If we are talking about "basic" service then if you feel you do not possess the skills or don't mind spending hundreds of dollars for an fluid change then I would make an appointment with your dealership for your next service.
Old Sep 2, 2015 | 10:11 AM
Heritage98's Avatar
Heritage98
I have always done all the servicing and most of the repairs on all my vehicles with the exception of tire mounting and A/C work. If you do it yourself you are more likely to keep your bike properly serviced and save a lot of $$$
Old Sep 2, 2015 | 10:46 AM
0425440's Avatar
0425440
Originally Posted by GroovusMagnus
It's a motorcycle, not a retirement account. If you're looking at your motorcycle as an investment, you should get used to disappointment.
GM
Perfectly said!
Old Sep 2, 2015 | 11:00 AM
03 Fatboy's Avatar
03 Fatboy
Always do all of the maintenance myself, I keep a log book of all work and save my receipts. Only time I use the dealer is for warranty repairs, never have a problem with the dealer refusing to do the work because I did the service work.
Old Sep 2, 2015 | 01:12 PM
lowend73's Avatar
lowend73
Originally Posted by traildog
I bought rhe bike in my sig pic a few days ago, and so far, I'm loving it!
I always serviced every bike I've owned myself, but I've never purchased a brand new one.
I know I CAN service this one, but, I'm not sure I SHOULD (in case of a warranty issue).
I bought the factory service manual, and, I'm good to.go, just a bit nervous I guess.
Have you done all of the servicing on your NEW bike?
I take mine to the Dealership for any warranty issues, and a local indy shop for tires.
By all means, you can service your bike. I'm not the most mechanically inclined(which is why i'm a Corpsman). With tools and the Service Manual you will be good to go. Youtube, and these forums are really good.
