Exhaust problems
Old Sep 7, 2015 | 09:46 PM
Zwells's Avatar
Zwells
1st Gear
Default Exhaust problems
Trying to use Vance and Hines duals on my 04 roadking, the system was previously on a 2011 bike. I found that the oil pan is different between the motors and that I can't currently fit the pipes on mine. Would it be a problem to use a newer model oil pan? Will there be a difference in oil compacity?
Old Sep 9, 2015 | 05:48 AM
grbrown's Avatar
grbrown
The oil pan on a '11 is the same as yours, so I don't think that is a solution. You can confirm by checking one of the on-line parts websites. I suspect the mounting to support the cross-over pipe must be on the trans housing, which is very different to yours. There is a member who has adapted a cross-over system to an earlier bike, but finding his thread may be a challenge!
Old Sep 9, 2015 | 12:28 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
The mounting point on the two frames are different as the frames were re-engineered in 2009. The exhaust you're trying to mount won't work without a lot of modifications. Easier to start over and get the right set-up.
Old Sep 9, 2015 | 12:39 PM
mkguitar's Avatar
mkguitar
When selecting new parts, think over changes and revisions to the models which may affect fit.
You can always run those ideas past here, as some of the Guys have a good idea of what-fits-what.
you can easily fit exhaust systems which are made for about 1995 to 2008 models on your bike.
2007+ have o2 sensor bungs which would need to be blocked
2009+ have a different frame...which is wider in the rear section and as you are seeing has a "crossunder" pipe for the left side muffler rather than the older style Y pipe at the rear header.
you can make that stuff fit ( and it has been done, there are threads you can search for) but it will cost you time and money.
Mike
Old Sep 9, 2015 | 02:21 PM
07custom's Avatar
07custom
https://www.hdforums.com/forum/touri...tra-glide.html
Old Sep 9, 2015 | 02:29 PM
grbrown's Avatar
grbrown
Thumbs up
Well done 07 and thanks!
Old Sep 12, 2015 | 10:51 PM
Zwells's Avatar
Zwells
1st Gear
Thanks for the help guys.
Old Sep 12, 2015 | 11:04 PM
qtrracer's Avatar
qtrracer
The 2009 and newer models do have a notch in the oil pan for the cross under pipe.
Old Sep 13, 2015 | 08:42 PM
Egldr05's Avatar
Egldr05
The newer pan fits without any issues.
Rick
Jim Bragg
Jun 4, 2021 03:34 PM
Rility
Oct 25, 2018 08:48 PM
BigKuntry
Exhaust System Topics
Dec 7, 2015 09:19 AM
David the Gnome
Sep 29, 2013 02:12 PM
NEW2BAG
Feb 24, 2008 01:11 PM
