FLHT 2007 charging issues
Old Sep 12, 2015 | 02:28 PM
mkguitar's Avatar
mkguitar
no crank with jumper wire from battery positive terminal to solenoid terminal ( where the green wire was)- then no battery power.
check your battery is charged ( on a charger, not a "tender")
check your cables are clean and tight at both ends
most OBD codes are now standardized- you can google each one....i don;t know how much sense they make given the current problem.
the part numbers are the tach and speedo
mike
Old Sep 12, 2015 | 04:40 PM
dodger413's Avatar
dodger413
i had the same problem this week on my 07.
it blew a fuse and threw the P0131 code.
after replacing the fuse and clearing the code, the bike started right up and back to normal.
good luck
Khshockey44
Electrical/Lighting/Alarm
Aug 19, 2018 02:15 PM
flhtc04
18
Apr 3, 2014 04:28 PM
skooter2000fb
Nov 15, 2012 11:04 AM
andyp
Sep 12, 2010 10:52 AM
sprgld71
Shovelhead
Sep 17, 2008 05:40 PM
