belt squeak
Old Sep 20, 2015 | 06:46 AM
oldhippie's Avatar
oldhippie
It's may be annoying if it happens when you reverse, but it isn't a real problem.
However if this starts to happen when you are going forward it is a problem and will get worse, and eventually no amount of goop, or soap or anything else will cure it. Most likely you need to get your rear swing arm bushings changed. Check that out before it cost you a new belt and a new rear sprocket.
How many miles on this bike? If you're over 50K this is a strong possibility. When was your last tire change? Consider doing it at the next one if you put on a lot of miles.
Old Sep 20, 2015 | 07:09 AM
mikeo33y's Avatar
mikeo33y
20k on bike. original tire. getting ready for new tire in a couple weeks. its just when backing it up
markkoby
Feb 3, 2020 01:41 PM
Bill Murray
May 2, 2013 12:22 AM
strange1
Jan 4, 2009 11:07 AM
clayman
Oct 15, 2006 03:08 PM
