2005 ultra classic primary drain plug
Old Sep 29, 2015 | 12:27 PM
Gitarded's Avatar
Gitarded
Some Harley mechanics will use a metric allen in there and strip it out for you. First day of class at tech school should be powertrain SAE everything else metric. Or maybe it is laziness.
That's why I do my own service. Had too many techie stripped bolts throughout the years.
Old Sep 29, 2015 | 12:55 PM
Weavr99FLHT's Avatar
Weavr99FLHT
Originally Posted by giacomo56
T27.....
Originally Posted by Retrop
A 1/4 hex or a 5/8" SAE socket will fit the primary, transmission or crankcase drain plugs. All 3 are the same.
A hex key will fit in the center of the plug or the SAE socket will fit the outside of the plug. Pretty handy.
Originally Posted by Woodchuck
1/4 inch allen head or 5/8 inch open end/box wrench?
It's in a note in the '07 manual in the section for changing Primary Chain Lubricant.
The OP Has an '05. The primary drain is an Allen head facing out, not the hex head facing down we have starting in 07. #22 in the photo
Old Sep 29, 2015 | 01:02 PM
CBud's Avatar
CBud
I have an 02. The primary drain plug is a T40 and the derby cover screws are T27. Not a hex.
Old Sep 29, 2015 | 02:16 PM
Bodean46's Avatar
Bodean46
T-27 Torks for the primary drain plug to the 2006 models. May have change in 07, not sure.
Old Sep 29, 2015 | 05:58 PM
Bill03E's Avatar
Bill03E
mine is a t-40
Old Sep 29, 2015 | 06:28 PM
EG-2006's Avatar
EG-2006
The primary drain plug on my '06 is a 3/16" Allen
Old Sep 29, 2015 | 07:03 PM
MikeySom's Avatar
MikeySom
What he say
Old Sep 29, 2015 | 07:09 PM
Bill03E's Avatar
Bill03E
Originally Posted by MikeySom
What he say
He is talking about the new style primary plug, or the same drain plugs that are for the trans , and oil drain on the older bikes.
Old Sep 30, 2015 | 05:41 AM
JONNIEROCK's Avatar
JONNIEROCK
So I have no more information than I did when I posted this. I have a service manual and I have tools . I just need to know what size torx or Allen wrench to use . In 2005 they have a small plug that comes out of the primary horizontally . It's not like the newer models with the drain bolt on the bottom .
Old Sep 30, 2015 | 06:17 AM
elPrez's Avatar
elPrez
I have an 05 Ultra, I'll check it out when I get home this afternoon
