Somewhere along the line Harley decided to change the specs. on the drive belt deflection on the FLH models from the old 1/4 - 5/16, and changed it to 3/8 - 7/16. My question is for the people with the older models ( I just bought a 2005 FLHTCI ) is, do you go by the old numbers or was there a good reason to loosen up the specs. and do you now go by the newer numbers or stay with the tighter ones.
Thanks Jonnierock
Stay with the spec for your year of bike. Belt width has changed over the years, from 1 1/2" to 1 1/8", to the latest 1". Belt construction has also changed, giving much stronger belts these days, which is why a 1" belt can deal with modern bikes which are much more powerful than the older bikes and their early 1 1/2" belt.
Reason: Grammar!
I was wondering if belt should be check after riding or cold. After I have tire off seams to take me a while to get it it so it's not tight hot but not to loose.
check cold and i've always set my belt deflection at the loose side of the specs, but always within spec. follow the service manual on wether they want rider on or off of bike when setting. some want you setting it at the tight spot and some at the loose spot. like i said follow the manual.
Go with the specs your bike called for until you install a replacement belt with the later material. So my original Kevlar belt went 3/8" to 1/2" and lasted 118,000 miles.
The carbon fiber belt that replaced it runs a little tighter, somewhere closer to 1/4" to 3/8" and has 34,000 miles on it. (Still running original tranny and inner primary bearings and seals too!)
Well, for that year, you bike was built like a brick outhouse.
