Ignition switch alignment tool
Old Oct 1, 2015 | 09:16 AM
just plain john's Avatar
just plain john
Sounds like good advice lp. It turns out that the 05 switch and the 09 in the video don't remove in the same manner. Instead of removing it from the full lock position, the 05 requires you to put the switch in the accessory position and use a small screwdriver to reach the button.
Old Oct 1, 2015 | 09:17 AM
Smokey Stover's Avatar
Smokey Stover
Originally Posted by just plain john
I have an 05, and it appears to be different than in the video. With it rotated far left past fork lock the corner of the switch where the release button should be does not clear the fairing and I can't get my finger under it. When viewed from the side I don't see the button either. I'll have to get my manual out.
Put key in and turn a little past lock to press button.
Ooops, glad ya got it lol.
Old Oct 1, 2015 | 12:56 PM
jmn1960's Avatar
jmn1960
my 05 removed from the acc. position ,, I got it miss aligned in the process of doing my repairs and just used a long screwdriver to re align it and it worked for me
mike
Old Oct 1, 2015 | 01:00 PM
just plain john
mike
Yeah, that's what my manual says too. Did you disconnect the battery ground before you removed the switch?
Old Oct 1, 2015 | 01:07 PM
jmn1960's Avatar
jmn1960
don't remember ,, but I don't think so as I was just changing the ing. switch cuz I broke the top of it off (don't ask)
mike
Old Oct 1, 2015 | 01:56 PM
iclick's Avatar
iclick
I'll echo what LP said in Reply #10. I've had my 2007 FLHX's ignition switch **** out probably 20x and never used an alignment tool. It can be removed in any position (off, acc, etc.) but must be reinserted in the same position. Forks can be moved around freely but I would avoid getting it too close to the fork-lock position (full left), as that may cause problems (never tested it but have heard warnings). BTW, a small screwdriver isn't necessary to flip the button under the **** if you have small fingers, as I always just used my pinkie.
I did get mine out of whack once when not paying attention and forgetting to install all the plastic and metal spacers first, then turning the ****. Once the tumblers were out of alignment a large-blade screwdriver got them back in place rather easily.
Old Oct 1, 2015 | 03:08 PM
Juan-The-Human's Avatar
Juan-The-Human
I'm wanting to pull my ignition switch and accessory switch panel. For those of you that built the alignment tool, what size copper tubing did you get? 1/4", 5/16", or what?
Flat Blade Screwdriver works perfectly fine if you accidentally get the internal parts misaligned. However, if you remove the I.S. correctly, and not turn the forks or anything, you shouldn't need a tool at all....just a tiny screwdriver to press in the lock on the underside. Good Luck.
Old Oct 2, 2015 | 03:46 PM
farmboy555's Avatar
farmboy555
Don't need a special tool. You can line it all up with a screw driver if need be.
Old Oct 2, 2015 | 05:19 PM
Dr. Tiki's Avatar
Dr. Tiki
I made mine, I felt the copper was too soft and flimsy. Bought some aluminum stock at Lowes, took measurements of the ignition switch and went to work.
Old Oct 2, 2015 | 05:28 PM
uphjmc's Avatar
uphjmc
Stage II
I used 5/16 brake line and it worked.
Bandit111
Aug 1, 2019 12:47 PM
Briguy1
Jun 18, 2017 07:43 PM
NWGlide
2014-2024 Touring Models
13
Apr 20, 2014 11:16 AM
Talldog
Dec 11, 2011 09:18 PM
Shrug
Jun 7, 2010 12:51 PM
