Flash2pass
Old Oct 3, 2015 | 06:37 PM
PTAG's Avatar
PTAG
Originally Posted by glcash
I have a 2015 Road glide special. Trying to hook up the flash2pass module to headlights. Anybody know what other wire besides the ground I need to tap into? They are all colored with a stripe.
It was very simple on my 2010 Street Glide.
I hate to say "read the directions" but you need to read the directions.
I just hooked my my second Flash2Pass transmitter. They work great. One wire goes to the ground. There are 2 other wires. The hook to the high beam and the low beam. It doesn't matter which wire goes to which. The instructions tell you it's the two vertical spades that you hook the wires to on the headlight plug. Hope this helps.
Old Oct 3, 2015 | 09:26 PM
glcash's Avatar
glcash
I hate to say "you don't understand the question"
Old Oct 3, 2015 | 10:00 PM
PTAG's Avatar
PTAG
Hmmmm.. Maybe not but let me try again. I have installed two of them and would like to help you if I can.
The Flash2Pass as I remember only has 2 wires coming out of the transmitter. As far as which wires to hook to for the other two wires just do as the instructions say. Look at the plug that goes into the headlight. There are three lugs that match up with the headlight bulb. Two go the same direction, we'll say vertical, and the other one is horizontal. You want to hook to the two vertical or maybe I should say the two that go the same direction. Look and see what color wires are hooked to those lugs. Follow them up in the harness a few inches or however far you want and hook the provided connectors to those 2 wires. I have one hooked up on my Street Glide and another on a Honda VTX. I don't remember the colors of the wires on the Harley but all you need to do is follow them up the harness. The harness does have a plastic tube for protection around it. Just cut the black tape and open it up to get to the wires. Tape everything back up when you are done.
I hope this helps. It's really the same answer as before so if this doesn't help please try to ask a different way. I am really trying to help. If you are looking for someone to tell you the exact color of the wires I can't do that but it's really easy if you just look at the plug.
Did that help or am I still not understasnding? I will be glad to PM you my cell number if that works better. Let me know.
Old Oct 3, 2015 | 10:34 PM
PTAG's Avatar
PTAG
Default Instructions
Sounds like you may have it figured out but just in case you misplaced your instructions I took a couple of pictures.
Hope they help.
File Type: bmp
File Type: bmp
File Type: bmp
File Type: bmp
Old Oct 4, 2015 | 08:40 AM
glcash's Avatar
glcash
There's 4 wires on the new roadglides, not 3 like the older street glides. Anyway thanks for your help. I have it figured out.
Old Oct 4, 2015 | 08:42 AM
glcash's Avatar
glcash
Hope they help.
Thank u!!
Old Oct 4, 2015 | 11:03 AM
luisan's Avatar
luisan
I like the idea of the "flash-2-pass" feature,would it be possible to add it to a 2006 Ultra and if so where would I buy it from?Thanks
Old Oct 4, 2015 | 11:14 AM
ROCKOUT Rocker Products
Sponsor
You can get the HD version for $116 + free shipping... http://www.boardtrackerharleyonline....tter-91558-01b
Works great on my '15 Limited Low.
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old Oct 4, 2015 | 03:13 PM
glcash's Avatar
glcash
Yes it will work on your 2006. Here's link. But you can google if it's sold out!
http://www.easternperformance.com/flash-2-pass-motorcycle-garage-door-opener.html
Old Oct 4, 2015 | 03:18 PM
dixonk's Avatar
dixonk
’14-later Touring and Trike models require separate purchase of Electrical Connection Kit P/N 69200722
That puts it over 150 bucks!
