’14-later Touring and Trike models require separate purchase of Electrical Connection Kit P/N 69200722
That puts it over 150 bucks!
But not neccessariy required.
Just installed this unit on my 15 SGS. All connections done in the fairing. Have to tap into the blue/white wire (high beam) however you install it, so I just tapped into the hot and ground leads feeding the power point also. The Electrical connection Kit you mention just allows you to plug the power leads into the connection behind side cover, but you still have to tap into a high beam wire.
The Harley version is $116. You don't need the harness, you hook into the high beam wire, a ground, and I used the cig lighter plug for the hot.
__________________
NO, they DON'T all do that!
ROCKOUT rocker shaft inserts... make the tapping STOP! From the guy that FOUND and CURED the problem NO ONE ELSE COULD, thank you for your support! Ordering & info http://www.rockout.bizOn ebay! ...CLICK HERE Also on amazon.com...
