Going from a 88" to 100", WITHOUT boring cases
Old Oct 6, 2015 | 12:58 PM
CornbredNE's Avatar
CornbredNE
Originally Posted by CornbredNE
The jugs would, pistons would have to be custom fit for the 4" crank. I'd guess someone will come with a piston in the near future.
S&S makes a 4" bore piston that should work with those jugs from Harley. Part #'s for the Harley jugs is 16800102 and the S&S piston part # is 92-1430.
Old Oct 6, 2015 | 01:31 PM
bikerlaw's Avatar
bikerlaw
Dang, well there you go. For whatever reason the O.P. has for fixating on a 4.00 x 4.00 motor, there is his solution. That's kinda cool, actually.
Old Oct 6, 2015 | 06:59 PM
just plain john's Avatar
just plain john
S&S has both 4" pistons and jugs in 1 kit. That's news to me, but it's just what the OP wanted. Strange that he hasn't replied by now. http://www.sscycle.com/product/4-Bor...ts-p24395.html
Old Oct 6, 2015 | 10:04 PM
bikerlaw's Avatar
bikerlaw
Yeah, strange. I'm guessing it was a "I want a square motor" idea, cause that's cool..... and then it wasn't. Lol.
Old Oct 6, 2015 | 10:11 PM
CndUltra95's Avatar
CndUltra95
Originally Posted by grbrown
If you insist on a 'square' engine the closest you are going to get is an S&S 111", which is 4 1/8" square. With a stock H-D crankshaft the largest bore available will give you 98", falling short on bore diameter by a mere 1/16". Surely that is close enough?!
But, it still aint a square motor.
Maybe the OP could look into a Merch Performance 100ci motor for his twin cam frame.
The Merch Motors where are Evo based and they are out there.
I know of a 100ci and a 120ci.
Best Regards,
Rob
Old Oct 8, 2015 | 09:45 PM
gaslog4's Avatar
gaslog4
Oh yes, I am still around...Thanks for the information, this is just what I wanted to know.. Thanks CornbredNE for the information also...If I have to purchase separate jugs, I will get in touch with you... I will be calling S&S tomorrow to see what they have available. Thanks for the back and forth also from the forum members also...
Old Oct 12, 2015 | 08:20 PM
gaslog4's Avatar
gaslog4
Called S&S and they no longer make the 100" kit any more...Looks like that the dream is over, am dead in the water because I probably cant afford to have custom pistons made even if Harley can provide the 4" Bore Jugs. Without the pistons I'm screwed...Thanks for all who contributed to the thread..
Old Oct 13, 2015 | 04:33 AM
Stiggy's Avatar
Stiggy
And never an explanation as to why 100" was so important in the first place.....
Old Oct 13, 2015 | 05:01 AM
just plain john
My thoughts exactly
Old Oct 13, 2015 | 10:36 AM
Joe12RK's Avatar
Joe12RK
does it matter? why judge him or his reasons?
