Any way to measure battery draw while bike is off?
Old Oct 7, 2015 | 11:21 PM
Time Machine's Avatar
Time Machine
Originally Posted by dlamar422
There's also a theory about your kickstand on a concrete garage floor grounding it and completing the circuit so it sucks the juice faster. I started using a plastic kickstand puck in my garage as a test.
When I bought my battery at the HD dealer, the parts dude told me this. I somehow graduated from college with a degree in electrical engineering, and have worked in the field for decades, and I think it's bs.
It does not seem like it completes any circuit, because it doesn't change the positive terminal. Plus, half the world ties netral wires to ground, and it does not really change anything.
And there's also kirchoffs law, which says that juice just cant flow into or out of the bike, there would need to be another path, which there is not that I can see.
Also, if you want to check the juice while the motors off, be carefull not to turn it on because many digital meters will blow a fuse.
Old Oct 7, 2015 | 11:22 PM
Crimson's Avatar
Crimson
Thanks for the suggestions guys this is exactly the type of info I was looking for. I'll give these a try over the next few days and see how things go.
Old Oct 11, 2015 | 12:03 AM
dlamar422's Avatar
dlamar422
I'm deathly afraid of electricity haha but my uneducated opinion agrees with you. I don't see how it would. The battery isn't connected to the frame and kickstand. I got 3 years out of one while a friend who doesn't battery tend all winter got six years. I'll never get it.
Old Oct 11, 2015 | 05:17 PM
GTK's Avatar
GTK
Well,it seems like all the responding posts were in agreement on how to check for a draw on the battery.So now you need to check it and return with your findings.
Old Oct 11, 2015 | 05:49 PM
btsom's Avatar
btsom
Except for which terminal to disconnect. If it were me, I would go with the negative terminal, no accidental sparks that way.
Old Oct 11, 2015 | 06:21 PM
wscott's Avatar
wscott
Today my bike barely started when I took it for a spin.. Rode it for about 15 mins and it started fine. Road for another hour or so and it was fine as well. I had last ridden about 2-3 days before today. I am wondering if I have something discharging the battery while the bike is off (I have an audio amp, LED's, and such connected).
Is there anything I can use to measure the draw (In amps or milliamps?) while the bike is turned off to see if I have one of those items that are connected pulling an unusual amount of current? The amp should turn off when the bike is off, and none of the lights are on.
I brought the battery into the local auto parts place and they said it was testing fine and if it was the battery going bad their tester would likely see an issue so they suspected either charging system or something drawing while the bike is off. I know there is some small draw from the radio and security system etc but after 2-3 days it shouldn't be hard to start.
Quick check is to 1st fully charge battery ,unhook the charger & unhook the neg batt cable.
Then let the bike sit 2-3 days ,re-attach ned bat cable and fire it up to see how fast the motor spins over before it actually starts.
If the motor spins over faster and or starts faster the motorcycle is definatley bringing the battery down in a short 2-3 days.
But keep in mind if the battery is not up to good operating capacity thats how it would act so the question at that point would be is bike pulling too much juice while sitting still in the garage over the few days or is the battery on its way out?
If battery comes into question just fully charge it again and take to your local HD shop/INDY/auto parts store to have it fully loaded tested to see what cond its really in.
Stock AGM factory activated maint free repl battery for HD tourirng bikes is 375-380cca /30AHR.
BTW,i know a few people that bought new Honda Civic's a couple yrs back and when they sat for 3-4 or more days without driving them with the security system on the battery would be low enough that they wouldn't start requiring a jump.
Scott
Old Oct 11, 2015 | 06:29 PM
Billyram's Avatar
Billyram
The easiest way to check for drain is to pull the main fuse and test in the sockets. If you see less than 5 ma you're problem most likely is a weak battery. When you first plug the probes in the draw will be high and then settle down to less than 2 ma.
Billy
Old Oct 12, 2015 | 07:53 AM
twistedcherokee's Avatar
twistedcherokee
Depending on their tester, it may not show up. Was it one that put a load test on it? The electronic ones that are the small handhelds sometimes don't have the capability to load it properly. I have seen some that had showed 200cca on a 500cca battery & say it is good. Did they say what it tested out as?
Toby
Old Oct 12, 2015 | 09:23 AM
Crimson's Avatar
Crimson
Just a follow up I finally got the equipment to test this properly. Looks like when I first connect the meter in series with the negative I get about 26-28ma until the ECM and stuff boots up and settles down and goes into sleep mode. After about 30 seconds or so I get about 7ma, and then it slowly trails off into the 1-2ma range. So I guess if there was a draw its no longer happening or that is not the issue.
I brought the battery in to another place to be checked and they told me it was putting out like 394 CCA (I think its rated for 400).. If I check the voltage myself it was sitting at like 12.64 after 2 days of not being charged so I think that's good as well.
So I think the last thing I need to check is the voltage output while charging.. What's the proper way to check that? Start the bike up and check the voltage at the battery like I would when its off? I assume I should be seeing 14.5 or so volts when running? (Might have to give it a little throttle?)
Old Oct 12, 2015 | 10:32 AM
btsom's Avatar
btsom
I hadn't noticed your add-ons before. What is the power draw for that amplifier? What else are you trying to power? This may be nothing more than too much equipment for the charging system to supply and the battery never gets fully recharged after a start.
