internal wire handlebars stock
Old Oct 16, 2015 | 04:28 PM
SnoRider's Avatar
SnoRider
Default internal wire handlebars stock
Say I have a 2011 flhrc. Say I want to add khromewerks heritage style bars. I think I can stay stock on all wires and cables. Please correct me if wrong. If I can, is there a way to run the wires into the bar without cutting them? Do they come out of the plug or whatever or do I have to cut the wire, run wire, and splice back together?
Old Oct 16, 2015 | 09:04 PM
Tiber's Avatar
Tiber
Yeah they come out. Service manual has instructions how to do this on all the different connectors.
Old Oct 17, 2015 | 05:22 AM
somorkc's Avatar
somorkc
Default Wires
Once you de-pin the wires from the connectors, turn bars over and drill hole at the end of the dimpled section. I used two layers of heat shrink to keep them from rubbing. Make sure you use a dremel to debur the hole. Did this on a sporty I'm rebuilding. Worked great. Do the same for the center of the bars where the wires will exit.
Old Oct 18, 2015 | 02:15 AM
ReidRik_Von's Avatar
ReidRik_Von
That is exactly what I did with the heritage bars on my FLHP. I posted some photos in this thread.
ReidRik_Von
May 25, 2014 03:03 PM
Matt0987
Nov 14, 2011 09:03 AM
Twrguy
Aug 2, 2011 08:56 PM
scuba1954
Mar 10, 2010 06:27 PM
drogers
Jun 1, 2008 06:26 AM
