Yes: another thread on cams...
Old Oct 20, 2015 | 02:39 PM
  #41
bklynbob's Avatar
bklynbob
Originally Posted by str8shuutr45
I'll put my $.02 in... I just had the 57H cams, V&H pro-pipe, S/E adj PR, SERT, and Dyno tune on the stock 103 on my 2013 Road King.
I couldn't be happier. I get great power through the range that I ride in and it's always there
That is lean. Was it tuned or did they just run it on a dyno and gIve you a sheet?
Old Oct 21, 2015 | 12:34 AM
  #42
Bluehighways's Avatar
Bluehighways
That's not Lean. In fact it's slightly on the Rich side of the Stociometric Curve. 14.7:1 is the ideal or Stociometric Air Fuel Ratio. Numbers greater than 14.7:1 (Example: 15.0:1) are Lean and the larger the difference the Leaner the mixture is. Numbers less than 14.7:1 (Example 13.2:1) are Rich Air Fuel Ratios. The Dyno Sheet he provided appears to be fairly stable between 14.0:1 and 14.3:1 with very few exceptions. Thus the Air Fuel Ratio he is running on this Dyno Sheet is slightly Rich. For maximum power at greater than 80% Throttle Opening you would probably want something between 12.5:1 and 13.5:1, but at anything less than 80% (50% at a minimum) you'll ant to be between 14.5:1 and 14.9:1. If not, you're just wasting fuel. There is no value in dumping lots of fuel into the engine to get more power at anything less than extremely large throttle openings.
Old Oct 21, 2015 | 06:34 AM
  #43
Keithhu's Avatar
Keithhu
Let me guess - tuned by a dealer?
Old Oct 21, 2015 | 06:53 AM
  #44
pittz5's Avatar
pittz5
Dyno results are done at wide open throttle. The bike should not be at 14+ at wide open throttle. This is very lean and doesn't appear to have been tuned correctly. Wide open runs should be 12.8-13. If this chart was showing a cruising afr then I'd agree with you.
Old Oct 21, 2015 | 07:24 AM
  #45
Scudda's Avatar
Scudda
Originally Posted by kryingame
What's up good Brother.
I'm using a place called, Busted Knuckle Motorcycle shop (https://www.facebook.com/BustedNuckl...RepairLLCSouth)
Dudes been around for over 30 years. Top reputation.
He loves Andrews 57 and hates Woods. I have the Power Vision tuner which is pushed by Fuel Moto. I don't think they provide maps for Andrews cams.
But again, I'm looking for reasons WHY folks chose their cams. I don't want to just choose a cam w/o having evidence to support it.
Thanks gang!
I put Andrews 48H cams in my Fatboy over the winter and got my PC3 USB tuner from Fuel Moto and they pre mapped it for my setup. I think they have maps for everything
Old Oct 21, 2015 | 07:52 AM
  #46
HKMark23's Avatar
HKMark23
I'm having a dilemma on choosing the right cam.
I have a 2012 SG. My mods are: CFR mufflers, Vance and Hines Headers, SE Air cleaner and Power Vision tuner.
I have no plans on doing any head work. I'm just looking to add more pep and torque when needed. My comfort zone is the 3000 - 5000 RPM zone. I do like riding a bit aggressive but when I'm cruising, I notice that I'm about 65 MPH at about 3000 RPM.
I called Fuel Moto and told this to Bob. His suggestions are the following:
Woods 222;
Woods 555;
Woods 777 (based on I enjoy higher end RPM's); and
999A6.
My Indy guy recommends the Andrews 57 Cam.
These are all good cams but I have no idea how to choose which is the best cam and I don't want to go through cam after cam in deciding.
For those who have chosen one of the listed cams, why did you choose so and what's your final opinion of your choice?
Please no arguments or lectures. Thanks!
This won't help .
Does Bob or your Indy have an opinion on the SE204? It is a drop in requiring no head work, comes on at about 2800 RPM, and pulls through the ranges you ride in. It also gives a nice lope at idle similar to the Andrews 57.
When I was looking for a "simple" cam upgrade for my Breakout the 204 was suggested as an easy do. I went with it and couldn't be happier. You'd loose a bit of low end grunt when starting off, "nothing serious", then benefit from greater pull in 2nd through 6th by staying on the cam.
Old Oct 21, 2015 | 08:49 AM
  #47
kryingame's Avatar
kryingame
Originally Posted by HKMark23
This won't help .
Thanks but I'm going with the Woods 777. They're all good compared to stock but this is the cam that my gut is telling me about. I'm no longer considering any others.
Right now, I'm just comparing prices.
Old Oct 21, 2015 | 10:18 AM
  #48
SBates08's Avatar
SBates08
Thanks but I'm going with the Woods 777. They're all good compared to stock but this is the cam that my gut is telling me about. I'm no longer considering any others. Right now, I'm just comparing prices.
That feeling in your gut is a sickness for MORE that haunts us all. Scratch that itch, you'll be glad you did. Just don't be surprised when it turns into a full blown rash once you scratch it.
2010 Limited with some stuff
Old Oct 21, 2015 | 11:34 AM
  #49
kryingame's Avatar
kryingame
My buddy is now a philosopher... And that's the reason why I decided on 777's vs. 222's. Gonna want more power.
Old Oct 21, 2015 | 12:45 PM
  #50
bklynbob's Avatar
bklynbob
I'm guessing reliability/longevity is no longer of concern....
