I have a 2011 Road King with a full size (width) screen that's 16" tall. I go 80mph on the highway ALL the time when I'm traveling and get north of 40MPG. I do better than that of two lanes. I have a SEPST, air cleaner, D&D Fatcat and dyno tune.
I'm fairly certain that Georgia gets winter blend gasoline.
Once hit a string of fill ups that produced low mpg. Checked and replaced the trifecta - tire pressure, spark plugs, air filter. Don't know which one was the culprit, but back to normal mpg afterwards.
If temperatures have started to drop where you're riding then the first place I'd look is tire pressures.
It's amazing how much a temperature change can effect your tire pressure. Even just from a cold morning to a warm afternoon this time of year you could see a change.
Another problem with basing it on just one fill up is that maybe there were a couple of days you rode with a 10mph or 15mph head wind that wasn't normal.
Trying to determine mpg on such small tanks really has to be done by averaging several fill ups.
I have a windshield also and ride most days to and from work for a total of 90 miles a day. For the last three months I have averaged 42.6, 42.4, and 44.2. I don't know that just your windshield would drop it that low. I did see a drop down to 39 once in September after a particularly very windy spell.
Ran my windshield for the first time for an entire tank of gas, went from getting 40 mpg to 33 mpg.
Is that normal?
No.
First you need to check averages over a number of fill-ups. If you haven't done this for your base (40 mpg) it may be high, which I doubt, and your one shot 33mpg may be low, which I suspect. I kept mileage records for "every single fillup" during my first entire year of operation, using a cellphone app, and outliers are not at all uncommon.
Over a year, with no changes to the bike whatever, measured mpg for my 2014 BO ranged from a high of 48.0 to a low of 37.9 with the average being 43.2 mpg for the year. Characteristically, most measurement values were concentrated around the average, "think bell curve", but outliers above 46.7 and below 39.7 (splitting your 7) were not exceedingly rare.
"People thought I was an obsessive nut job for keeping these records but you've made it all worthwhile,, thanx".
If the wind isn't hitting the windshield, its hitting you. I'd be awfully surprised at a consistent 7 mpg difference because of a windshield.
I average around 42 with just normal riding, around 38 when I'm getting on it.. I use the regular math method and my pv. I'd agree that it would take a few tanks to get a good average number tho.. With such small amount of gas it wouldn't take much of a difference gallon wise to change get the overall number.. Maybe your a big guy and your causing more resistance lol who knows
to many variables,gas with more crazy alcohol content, headwind,temp, humidity,passenger,bricks in saddlebags, tank a little less full than last tank.
Theoretically, the relative amounts you put in don't matter as long as you record miles and gallons. That said, reading and rounding errors become waay more significant if you record a series of 1/2 fills and 1/4 fills vs near 100% fill-ups, resulting in more mpg outliers.
Yours seem to be about right. But inside with my windshield All the time
All you guys that get over 42 mpg are straight liars or have really long commutes or drive below 60 mph. My avg speed is 65-80mph.
