Fastener size
Old Oct 31, 2015 | 06:19 PM
Cozz's Avatar
Cozz
Default Fastener size
Does anybody know what size of torx, or Allen or whatever fits these things. T30 doesn't fit in tight, neither does any Allen, sae or metric. WTH? Finally had to break them loose very carefully with a vice grip. What gives?
Old Oct 31, 2015 | 06:37 PM
Eunoterpsia's Avatar
Eunoterpsia
Well, now that you have broke them loose... why not extract them using the same method... take to Home Depot and replace them with more user friendly bolts
Old Oct 31, 2015 | 07:06 PM
Cozz's Avatar
Cozz
That is a Capital idea, but I'd still like to know what they are.
Old Oct 31, 2015 | 07:08 PM
Uncle Larry's Avatar
Uncle Larry
http://www.wihatools.com/Marketing/torxspec.htm
Old Oct 31, 2015 | 07:17 PM
Cozz's Avatar
Cozz
I saw that chart earlier today investigating wether there was a t35 torx, no such thing. T30 stripped/spun in the hole. T27- way too small, t40 way too big. Some special HD size maybe? Available only at HD? Hahaha
Old Oct 31, 2015 | 08:21 PM
Eunoterpsia
FLHTCUI FC ELECTRA GLIDE ULTRA CLASSIC (EFI) (2004)
according the fiche it is supposed two hex heads on either side which secure the support tube (for the license plate).
Item 9, part number 4017...
9 4017 BOLT 5/16-18 X 1 hex hd. (Grade 5) | DD/DJ/FB/FC/FD/FF/FR/FS/FV/FX/FY $1.05
I know that doesn't help you... but something is all backyard jacked!
Old Nov 1, 2015 | 07:44 AM
Cozz's Avatar
Cozz
Thanks for the diagram. I replaced part 29, the original was rusty. Added a lay-down plate for the tag. Looks soooooo much better.
Old Nov 1, 2015 | 08:42 AM
grbrown's Avatar
grbrown
If you are referrig to the pair of screws in your photo, they are described as:
3676, SCREW 5/16-18 X 5/8 TORX pan hd
If you have the parts book that may be more specific. In any event, it seems they are certainly Torx, which they also look like.
Old Nov 1, 2015 | 09:29 AM
voodoodrug's Avatar
voodoodrug
interested too, ive heard that HD uses some odd sizes or maybe called security...maybe a HD tech will chime in
Old Nov 1, 2015 | 10:26 AM
04glideTC's Avatar
04glideTC
I just replaced the same bolts. Used arp stainless 12pt bolts.
