Road King Performance upgrade needed!
Old Nov 10, 2015 | 05:15 PM
rking1550's Avatar
rking1550
Originally Posted by Road Star
OK. Good point.
The compression test just returns PSI, correct? Is there a formula to determine the other factors? Not sure what they are called.
Try bigboyzheadporting.com good site use their twin cam compression calculator. You just put in all the info you have the calculator does the rest.
Engine size
Bore
Head gasket thickness
Head cc's
Piston dome cc's
Cam that your using (or want to use)
Spend a little time there is s great tool to help figure things out.
Old Nov 10, 2015 | 08:46 PM
0ldhippie's Avatar
0ldhippie
Compression test psi number and CCP (cold cranking compression) are the same thing. Ya can use the bigboyzheadporting.com calculator to figure out everything else after ya have a starting point with a compression test.
Old Nov 11, 2015 | 09:53 AM
bigheadted's Avatar
bigheadted
If it were me in your shoes the one thing I would do is have compression releases installed while the heads are off. Nothing wrong with being easier on the starter on the ol girl.
Old Nov 17, 2015 | 11:22 PM
Road Star's Avatar
Road Star
Well, I was hoping to just do the cam and the cam-plate.
Went to the Rocky Point rally this past weekend, the motor got hot waiting in line at the border. We stopped right after and waited for everyone to get across before we got going again. When I took off, a short time later, it was really hard to start. Running kinda slow and sluggish, I looked down and saw only 20 psi oil pressure. It took about a mile, riding real easy before the pressure came back up to 60-70, which was where it normally ran.
Hoping I didn't do any damage, got me home, another 400 miles that day.
Old Dec 19, 2015 | 01:50 AM
Road Star's Avatar
Road Star
Ok. Looks like I'm going with the Andrews 37G cams. Stock Springs will work.
Anyone purchased these recently? Looking for a good price.
brc0703
Mar 24, 2019 03:17 AM
Dyna7
Engine Mechanical Topics
Jul 30, 2014 04:58 PM
Artyom
EVO
May 13, 2013 12:01 AM
Artyom
Exhaust System Topics
Mar 7, 2013 12:18 AM
doakley2
Apr 13, 2007 01:30 PM
