New rim question about direction
Old Dec 16, 2015 | 06:01 AM
SBates08's Avatar
SBates08
Originally Posted by pontiac69
I just checked my original wheels. It has the marks that say DOT on the right side. Also I see the abs sensor on my bike, it's on the left side.
Just check the new wheels abs bearing and put it to the left side regardless of DOT stamp. The instructions that came with my Chrome Enforcers stated that the DOT stamp goes to the left but I've seen several from the factory that were "backwards" so you'll be fine.
Old Dec 16, 2015 | 07:17 AM
skratch's Avatar
skratch
depending on the wheel, the valve stem may not be in the center. so if you have your wheel on backwards, the valve stem will be on the wrong side. i'm not sure how they are on the 2015s (enforcers), haven't looked at them that closely.
Old Dec 16, 2015 | 07:34 AM
SBates08's Avatar
SBates08
They're in the center. And it's a breeze to put air in them too.
Old Dec 16, 2015 | 01:33 PM
pontiac69's Avatar
pontiac69
skratch are you trying to be funny?
Remember i am only asking because it looks like the bearing on either side look slightly different as well as one sits in more than the other.
I was just looking at the new rim. It has the DOT logo embossed on one side. Should that go on the left side like Sbates08 suggested? I want to be sure to keep the spacing correct.
Also is there anything different between the abs and non abs install of the wheel. Watching the video i posted, that was for non abs. Do i assume its the same for abs in that it just has the sensor that the axle needs to go through? I will attach a pic of the wheel.
Wait, is the axle tapered? Meaning its larger on the right side and smaller on the left where the threads are? If that is the case then its obvious which side is right and left. Sorry for the stupid questions but i have never changed out a rim on my bike.
Attached Thumbnails New rim question about direction-img_1804.jpg   New rim question about direction-img_1803.jpg   New rim question about direction-img_1802.jpg
Old Dec 16, 2015 | 03:39 PM
SBates08's Avatar
SBates08
skratch are you trying to be funny? Remember i am only asking because it looks like the bearing on either side look slightly different as well as one sits in more than the other. I was just looking at the new rim. It has the DOT logo embossed on one side. Should that go on the left side like Sbates08 suggested? I want to be sure to keep the spacing correct. Also is there anything different between the abs and non abs install of the wheel. Watching the video i posted, that was for non abs. Do i assume its the same for abs in that it just has the sensor that the axle needs to go through? I will attach a pic of the wheel. Wait, is the axle tapered? Meaning its larger on the right side and smaller on the left where the threads are? If that is the case then its obvious which side is right and left. Sorry for the stupid questions but i have never changed out a rim on my bike.
The 1st of the wheel with the grey bearing is the left side (abs). I can also see the DOT stamp at the 10:00 o'clock position in that same pic. Once you start tearing yours down you'll see how everything goes. ABS sensor is your spacer on the left side and a regular spacer on the right. Make sure on reassembly to rotate the ABS sensor counter clockwise till I bottoms out against the tab or it won't work properly. And DO NOT over tighten the axle cap nuts.
And no Skratch wasn't trying to be funny. Some wheels have the valve stem off center to the right to make getting to them easier when the bike is on the Jiffy Stand.
Old Dec 16, 2015 | 03:59 PM
pontiac69's Avatar
pontiac69
Ah i see. The one bearing has the part number and is black. The other is grey and no part number shown. That is the abs side? I will keep a close eye on the disassemble and reassembly on the abs side.
Do you know if the axle is tapered or is it straight? I have no idea.
Old Dec 16, 2015 | 04:20 PM
SBates08's Avatar
SBates08
Ah i see. The one bearing has the part number and is black. The other is grey and no part number shown. That is the abs side? I will keep a close eye on the disassemble and reassembly on the abs side. Do you know if the axle is tapered or is it straight? I have no idea.
Yes the grey is the abs bearing. Your axle looks like this. Only difference is you only have one spacer like these.
Dudepants
Nov 5, 2022 07:11 AM
Seahorse
Apr 14, 2019 01:16 PM
tmultra
Feb 7, 2019 06:16 PM
Iron lHorse
Dec 21, 2018 04:10 PM
devildocjames
Mar 13, 2018 08:18 AM
