Tire mounting question
Old Jan 6, 2016 | 12:53 PM
bigheadted's Avatar
bigheadted
I ran dyna beads for years and loved them. I recently switched to Ride On tire sealant and balancer and so far after about 5k miles I am liking the balance and the added insurance for a puncture.
Just thought to share .
Old Jan 6, 2016 | 12:56 PM
Talldog's Avatar
Talldog
Thanks, I'll look into that!
Old Jan 6, 2016 | 02:29 PM
glasspilot's Avatar
glasspilot
Originally Posted by Talldog
Thanks everyone, I'm gonna be removing and replacing the bearings anyway, I do it whenever I put on new tires.
Old Jan 6, 2016 | 03:24 PM
Talldog's Avatar
Talldog
Originally Posted by glasspilot
What is it that you don't understand?
Old Jan 6, 2016 | 05:33 PM
'05Train's Avatar
'05Train
He's probably wondering why you'd change them so frequently (and every tire change is a bit excessive). Honestly, they're cheap enough that it's not hateful to do them every 10-12,000 miles when you've got the wheels off as a safety measure.
I do mine every other, and haven't had a problem with them.
Old Jan 6, 2016 | 06:09 PM
sanman4ever's Avatar
sanman4ever
Which bearings are you guys using as a replacement?
Old Jan 6, 2016 | 06:36 PM
Shanebo's Avatar
Shanebo
I just wasn't sure if when I take the wheels to have the tires installed, the bearings needed to be removed or not.
In other words, I don't want to remove the bearings, and then find out they need to be in for the way they attach to the tire machine.
I'll just give the installer a call, I just figured someone had been through this before.
Thanks
The balancers I use allow for a wide range of diameters at the axle hole. I'm sure that the cones would fit into the center of the wheel, whether or not the bearings were in at the time.
The bearings that are used to actually balance the wheel are more precise than the wheel bearings, so the wheel ones only act as a place to pinch between the balancer cones.
Not my video, and I have since moved on to a better item than the one in the video, but the principle is the same...and you can see how the wheel is held by the cones.
If the shop uses a cone-type of holder for the spin balancing, you might be able to bring them either way. I'd just ask the shop.
All the best,
Shane
Old Jan 6, 2016 | 07:48 PM
glasspilot's Avatar
glasspilot
Exactly. I'm about to turn 61,000 on my 06 Ultra; original wheel bearings. But everybody has their thing.
Old Jan 6, 2016 | 07:55 PM
'05Train's Avatar
'05Train
I'd suggest that you're pushing your luck with yours.
Old Jan 6, 2016 | 08:33 PM
lp's Avatar
lp
The 1 inch bearings were much better than the 25mm crap we have now.
