help
Old Jan 20, 2016 | 04:08 PM
biker61's Avatar
biker61
Stage III
Default help
i have a 2003 ultra classic wint on a long ride and it got hotter thin its ever now its making a cherping noise dont want to tear in to it with out getting some feed back on what it might be
Old Jan 20, 2016 | 04:22 PM
nytryder's Avatar
nytryder
Off the top of my head I'd pull the cam cover off and have a look. Most likely something in there is amiss.
Old Jan 20, 2016 | 04:28 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
how many miles and if or when were the cam chain tensioners done?
Old Jan 20, 2016 | 04:31 PM
bigdumbnoitall00
chirping can come from a lot of places usually rubber,the rubber muffler mount are common. could even be a motor mount.
Old Jan 20, 2016 | 08:08 PM
riteway's Avatar
riteway
First of all....Welcome!! Chirping is a tough question as has been noted..Please give us more info on were said Chirping is coming from....I have chirping that comes from my 04 and once it cools down it stops....Good Luck....
Have you done a search???
https://www.hdforums.com/forum/searc...rchid=33344184
Old Jan 21, 2016 | 06:18 PM
biker61's Avatar
biker61
Stage III
have 20k miles and have not changed them was in good shape6 months ago and have not noticed power lose
Old Jan 21, 2016 | 07:06 PM
twistedcherokee's Avatar
twistedcherokee
First try to locate the area that the chirp is coming from. My 99 had a head gasket go bad & chirped at start up. Found it when I washed the bike & started it up to pull it inside, saw the water spraying out at the bad spot. Use some wd40 or silicone spray on the rubber pieces that hold your exhaust towards the rear of the bags, if it goes away, it is there. Good luck
Toby
Old Jan 22, 2016 | 06:32 AM
grbrown's Avatar
grbrown
Hi from the UK and welcome to HDF. Noises of any kind are difficult to hear over the internet! Having started chirpoing, does it continue to do it if you pull over and leave it running? If so get off and walk around, to see if you can identify where it's coming from. Better still get a buddy to join you, so there are two pairs of ears.
Old Jan 22, 2016 | 10:12 AM
Roadflyer's Avatar
Roadflyer
Chirping when the engine is running and the bike is stopped or when moving?
chirping when the bike is moving but the engine is off?
Old Jan 23, 2016 | 07:31 PM
breeze3215's Avatar
breeze3215
I know it could be a number of things. when my 08 was chirping,it turned out to be a bad roller on a lifter,and at only 14000 miles.
