Champion spark plug # please
Old May 10, 2007 | 10:56 AM
jd_underdog's Avatar
jd_underdog
Default Champion spark plug # please
i did a search and could not really find what i need. does anybody know what the champion sparkplug # is for a 2000 roadking classic? i need to replace my plugs and have read that the champions are the same as the hd plugs. any body know the # so i can go get a set? also what should the gap be set at? thanks
Underdog
Old May 10, 2007 | 10:58 AM
berettag's Avatar
berettag
Default RE: Champion spark plug # please
I believe it's the same as an Ultra, RA8HC, gap is 40
Old May 10, 2007 | 11:01 AM
berettag's Avatar
berettag
Here ya go
<TBODY>
Spark Plugs for
Twin Cam Engines
<TBODY>Plug Manufacturer
TC88/95 Engine
Plug Gap[/i][/b]
.040"[/i][/b]
H-D Standard
6R12
H-D Gold
6R12G
H-D Platinum
6R12PP
Champion
RA8HC
Autolite
4164
Autolite Platinum
AP4164DP2
ACCEL
2418
Y2418P
Splitfire
SF416D
Screamin Eagle
EX12S
EX12P
ACDelco
NGK
DCPR7E
Bosch
Denso Iridium[/b]
IXU22</TBODY>
</DIV>
Spark Plugs for
80 CID Evolution Engine
80 CID Evolution 1984-up
Plug Gap[/i][/b]
.040"[/i][/b]
H-D Standard
5R6A
H-D Gold
5R6AG
H-D Platinum
5R6APP
Champion
RN12YC
Autolite
4265
Autolite Platinum
AP4265DP2
ACCEL
2410A
Splitfire
SF6D
Screamin Eagle
EVS13S - Hot
EVS13P - Cold
ACDelco
44NS
[font
Old May 10, 2007 | 11:17 AM
jd_underdog
berettag, thank for the info i really appreciate it!
Old May 10, 2007 | 12:17 PM
lottinala's Avatar
lottinala
i wouldnt run champions in my sons bicycle. ive never had any luck with them. they tend to foul out quicker than any other plugs ive used. im going with ngk's when i change out there like a timex they take a licken and keep on ticken.
Old May 10, 2007 | 02:30 PM
Neckball's Avatar
Neckball
Check what's currently in your motorcycle, I'm betting they're Champion. Foulded out yet? To me, changing brands would be like fixing what isn't broke regardless of the brand that's currently in the engine. I'd say plug fouling is usually caused by many things other than the spark plug itself. But we all have different preferences, for whatever reason.
Old May 10, 2007 | 04:56 PM
wildpig1ms's Avatar
wildpig1ms
I have a '97 Road King with an S&S carb and before that a modified factory carb. I've run Split Fire, Harley, Champion, and now, the regularAutolite - the Autolites have lasted much longer thanthe others (I'm at7,800 on them now compared to 5,000 with the others). They tend to handle rich mixtures better and burn off where as the Champions and Harley's would just foul out and have to be cleaned or replaced. I've just gotten a set of NGK iridium plugs to try out whenever the Autoliltes need replacing - would have gotten the Autolilte iridiums but my parts house didn't have them....
Can't tell by advertising how any will run, my cousin that works at the parts house told me about how the Autolites worked well in an old hunting pickup that he had that would run rich on start up, the Autoliteswould burn off and run fine whereas the others would just stay fouled......it's worked for me!
Of course, as always, YMMV !
Old May 11, 2007 | 09:11 AM
jbhawley's Avatar
jbhawley
hey lottinala
if you are running HD branded plugs then guess what...
you have a champion plug.
Champion makes plugs for HD..put the HD logo on them. Do you really think HD makes anything but bikes.
HeLL...kurykan makes most of their chrome accessories. Seems like i read that sunoco or citgo make the oil, HDC makes the helmets. Thats just business.
Old May 11, 2007 | 10:39 AM
lottinala's Avatar
lottinala
ORIGINAL: Neckball
you almost right that is what came in my bike but didnt stay long i pulled them and went with NGK, is like mods for most the first thing gone was those stock plugs and in with NGK's. i dont want to be stuck on the side of the road with fouled plugs and just so happens went down to thunder beach last weekend and one of the guy riding a v-rod had stock plugs (champions) and on the way back just north of montgomery we were looking for a parts store so he could put plugs in because in a matter of 150 miles the bike would not run, it started out with every time he would give it gas to pass it would flood and finally he had to limp it to a parts house. changed plugs and run great. by the way the plugs in it wasnt but about 3000 miles old.
Old May 11, 2007 | 10:42 AM
lottinala's Avatar
lottinala
ORIGINAL: jbhawley
hey lottinala
if you read the post above you will see that i changed my plgs like a mod as fast as i could. as for all the parts your right they dont make alot of the things on the bike like carb,forks,shocks,guages and the list goes on and on and if you realy get down to it all they are is a place that put the bike together.
