Stator Replacement
Old 02-12-2016, 12:49 AM
hellmut73's Avatar
hellmut73
hellmut73 is offline
Default Stator Replacement
My Stator is leaking oil from the rubber grommet on the motor case. I have tried to apply black RTV to no avail and have to replace it. It works fine but the leak is driving me nuts!
Question: Does anyone know what the amp output is on the stock stator for a 2010 ultra? Does anyone have the Accel 50 amp stator?? Any comments help. Basically trying to figure out if I should just replace it with another HD stator or go to the Accel 50 amp stator. Thanks
Old 02-12-2016, 01:29 AM
Road Star's Avatar
Road Star
Road Star is offline
More is better... in most cases. Or, some cases?
Either way, maybe go with a new voltage regulator too.
Old 02-12-2016, 03:57 AM
Rodzilla6's Avatar
Rodzilla6
Rodzilla6 is offline
That stinks. But if you have to change it, it's not a hard job at all. Did mine last year along with the regulator.
There is a little trick to make it easier to change and more info if you do a search.
You have to pull the outer primary, but you don NOT have to pull the inner, which makes the whole job MUCH easier, if you do the following.
There is a little extra casting material that was left on the outer primary (inside the casing, unseen...) that stops you from pulling the stator off. It's only about 3/16's and comes off real easy with a dremel, etc. Cover the area with cloths and keep it clean. Very easy and much easier than pulling the inner primary.
It took us about an hour and a half including beer drinking and no drama...lol.
Easy...hope it works out.
ps I went aftermarket stator...my original was scary fried...
Old 02-12-2016, 04:33 AM
misfitJason's Avatar
misfitJason
misfitJason is offline
Received 1,031 Likes on 652 Posts
Old 02-12-2016, 06:03 AM
Vernal's Avatar
Vernal
Vernal is offline
Received 7,334 Likes on 1,913 Posts
50 amp.
http://partsfinder.onlinemicrofiche....GE%20REGULATOR
Old 02-12-2016, 06:38 AM
leon anthony's Avatar
leon anthony
leon anthony is offline
the stock ultra stator is 50 amp
dougbk's Avatar
dougbk
dougbk is offline
Try a sealant called "The Right Stuff" it has worked for me. It isn't cheap. I clean and dry the grommet then pull it up slightly to get the sealant under the edges and then seal all the way around the plug. I have used it on a couple of bikes and it worked.
Old 02-12-2016, 06:48 AM
Campy Roadie's Avatar
Campy Roadie
Campy Roadie is offline
Received 5,063 Likes on 2,501 Posts
I would drain the primary and brake clean the plug from the inside. Then I'd high temp silicone that thing from the inside and outside. I'd never replace a working stator over a leak. Not on my dime anyway. Now if it was warranty that's another matter.
Old 02-12-2016, 12:12 PM
03 Fatboy's Avatar
03 Fatboy
03 Fatboy is offline
This is what I would do too. I would reuse the primary gasket also if you don't tear it when taking it off. I have reuse this gasket multi times without leaks.
Old 02-12-2016, 12:17 PM
hellmut73's Avatar
hellmut73
AHHH! Thanks to all. This will be my second trip into my primary. I originally thought the leak was from the primary gasket. But nope!. I have "the right stuff" sealant. I think I will seal the new one inside and out. Why replace the regulator? Thanks to all.
128auto
06-04-2015 08:29 PM
mballard
Shovelhead
18
09-26-2014 03:16 PM
watindes
EVO
07-13-2014 08:20 AM
SoftailCustom83
08-10-2013 01:45 PM
RexHog
06-28-2011 04:32 PM
Quick Reply: Stator Replacement
