LOSING AIR PRESSURE
Old May 12, 2007 | 12:03 AM
Sreynold1's Avatar
Sreynold1
Default RE: LOSING AIR PRESSURE
Glide, thanks for the good advise...That's why I like the "FORUM".
Old May 12, 2007 | 12:24 AM
Madbagr's Avatar
Madbagr
Like the glide says, the fittings on the shocks themselvesmay the culprit in your case because they are on many others. Had mine done under warranty while in for a service, but if you're not covered or between services and want minimal down time, back the nut off and cut a quarter inch or so off the plastic piping and then snug the fitting to spec. The fresh seat should last you a long time.Hope this fix works for you too.
Old May 12, 2007 | 01:07 AM
mikeisglidn's Avatar
mikeisglidn
i replaced my lines with "tank valves" lie what comes in an air tank, fill them up seperatlly 2 years aint lost a bit of air no more problems
Old May 12, 2007 | 01:29 AM
md168's Avatar
md168
I had problems getting air into my newly installed HD low profiles, it wouldnt hold any pressure. I looked closely at the black tubing on the end that slid into the red coupling. The ends had indentations around where the old seal was...I cut off the tubing atthe tipsand reseated them..It finally is holding pressure , over a week now w/ no leaks. Im not sure how that fitting is designed to hold the pressure, but it worked. Also, make sure you push the coupling in, seat the tube and pull it back out for a good fit.
Old May 12, 2007 | 01:47 AM
CSI's Avatar
CSI
ORIGINAL: glide
Have you replaced the origional air in the shocks as yet?
I heard that replacing the O.E. Harley air, with regular atmospheric air will void the warranty?
I just bought an 02 Ultra. No owners manual with it (of course). Where the heck is the valve for the rear shocks? I have looked under the tourpack, behind both saddlebags, on both side covers, etc. Please don't tell me it's under the seat.....
unless you have to
Old May 13, 2007 | 12:58 AM
Sreynold1's Avatar
Sreynold1
,New2Harley
The valve on my 06 is on the left side on the fender strut, right below the seat. If you lift the left saddle bag lid, you will see the fitting.
Old Oct 5, 2014 | 08:43 PM
namvet047's Avatar
namvet047
4th Gear
i was told by harley dealer that losing air on my tri-glide was normal what ever since that makes
Old Oct 6, 2014 | 05:10 PM
cficole's Avatar
cficole
unless you have to
Go to the H-D website, download an owner's manual.
https://www.harley-davidson.com/cont...rs-manual.html
Old Oct 6, 2014 | 05:32 PM
RollaMo's Avatar
RollaMo
I would hope that since he posted that 7 years ago, he has the manual now.
Heck, he might even have a new bike by now.
Old Oct 6, 2014 | 07:19 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
There something about releasing air from the shocks using the pump and if you have the owners manual check out the air suspension section for psi vs. weight.
