Pulled the code and got P0562
Old May 12, 2007 | 02:02 AM
Softtail Bob's Avatar
Softtail Bob
Default Pulled the code and got P0562
Well this means Low Battery Voltage and I can not clear the code. I held it down longer than 5 sec and it did not erase. Any advise on wheter I shold go in the morning on our trip? The bike seems to be running good.
Old May 12, 2007 | 02:54 AM
TexasRedneck's Avatar
TexasRedneck
Default RE: Pulled the code and got P0562
Either ya got a battery or an alternator goin' on ya. I wouldn't leave until ah had it figgered out an' corrected.
Old May 12, 2007 | 02:57 AM
the_icemAN's Avatar
the_icemAN
double-check your battery connections. sometimes 1/4 turn makes all the difference in the world.
Old May 12, 2007 | 05:03 AM
RBJones's Avatar
RBJones
Make sure the terminals are clean, too. If you're that concerned, and the battery is getting old, I'd buy a new one before heading out on a long trip. Better than getting stuck in Bugtussle for a day waiting on a battery.
ORIGINAL: the_icemAN
Old May 14, 2007 | 09:34 PM
Softtail Bob
I went to theHD shop on Saturday morning with the Low Battery Voltage code, turned out to be two loose Ground wires under the tank/seat area.
Old May 14, 2007 | 10:26 PM
Bigredone's Avatar
Bigredone
Did you get the recall on some of the voltage regulators?
Old May 14, 2007 | 11:14 PM
Softtail Bob
No I did not get the recall. The tech changed the regulator while I waited but it was still throwing the code so he started looking around and found the loose grounds.
alee18
Aug 8, 2018 03:21 PM
cpudoc
Apr 7, 2015 11:18 AM
Golfinds
Dec 20, 2014 06:43 AM
Curious.Yogurt
Jun 26, 2009 10:26 PM
realmccoy
Jun 23, 2009 05:42 PM
