howard horn mount question
Old May 12, 2007 | 08:50 AM
relli's Avatar
relli
Default howard horn mount question
LOVE these horns but small problem is driving me NUTS. the install had me put the rubber mount behind the cowbell. no matter how hard i try that rubber mount will not allow me to position the cowbell so that it stays vertical. always leans to one side or the other. the mount already has the main rubber mt-think if i put a metal spacer behind the cowbell that i'd be safe????or would i stress/crack something??
Old May 12, 2007 | 02:50 PM
ragingbull's Avatar
ragingbull
Default RE: howard horn mount question
Is the mount intact? I ended up buying another one from HD because mine tore trying to get it off. My cowbell sits level.....
Old May 12, 2007 | 04:09 PM
SoCal_Pappy's Avatar
SoCal_Pappy
Installed one on my '01 RG and had no problem with thw cowbell and the rubber washer - it was the air hose to the horn that was causing the bell to **** to one side... I put a longer braded hose and it worked fine after that... You want the rubber washer as it does allow for some movement nad a solid buehing\spacer may cause the mount to crack in time...
TriGeezer
Jun 29, 2016 07:16 PM
traildog
EVO
31
Sep 9, 2014 08:53 PM
essentialcycle
Oct 4, 2012 08:15 PM
socal yankee
Air Suspensions
27
Aug 15, 2011 08:56 AM
wildog57
Feb 4, 2010 10:26 PM
