Ohlins Adjustment
Old Feb 22, 2016 | 09:39 AM
tsigwing's Avatar
tsigwing
Default Ohlins Adjustment
So if I adjust the the #3-#3 shock so that it is as long as it can be, what will that do for me? I am a tall guy with long legs, so that isn't a issue, but my bike has a centerstand, so I do on occasion bump it or drag it and am hoping that if I make the shock as long as possible, it may get me more ground clearance.
Old Feb 22, 2016 | 11:42 AM
PFWiz's Avatar
PFWiz
LOL...
All you will do is make it ride like sh*t. The bike will have zero sag and will ride like a hard tail.
None of the adjustments are designed to change ride ride height.
Old Feb 22, 2016 | 11:48 AM
Leftcoaster's Avatar
Leftcoaster
Seems the 3-3's are length adjustable. Make them as long as you want, just remember to set the sag for the amount of travel you have.
Old Feb 22, 2016 | 11:52 AM
batman.'s Avatar
batman.
Call howard maybe he can help you out with them.
Batman
Old Feb 22, 2016 | 12:41 PM
vizcarmb's Avatar
vizcarmb
Why didnt you get the 3 - 4 ????? Longer length same stroke. You cant really do much since you put the centerstand on. What did you expect when you installed the centerstand? You want clearance???? Remove the centerstand
Old Feb 22, 2016 | 03:25 PM
tj316's Avatar
tj316
The length adjustment on the bottom will change nothing but add ground clearance , you need to make sure your center stand works with the increased height , the adjustment will not affect your sag as you are not adding stroke length
Old Feb 22, 2016 | 03:44 PM
the warden's Avatar
the warden
Yes, this.
Bluraven
Jul 26, 2023 03:34 PM
Jackpoticorn
Jan 18, 2015 09:58 AM
odieodie
2014-2024 Touring Models
26
Apr 6, 2014 09:03 PM
spankdog
Jul 29, 2012 05:05 PM
PFWiz
Mar 23, 2012 10:03 PM
