Changing brake fluid on ABS bike.
Old Mar 7, 2016 | 11:07 AM
pt4u2nv's Avatar
pt4u2nv
Default Changing brake fluid on ABS bike.
Manual says you should use special bleeder to prevent air from being introduced into the system. I have a air operated brake bleeder that pulls the old fluid out and replaces it with new from a reservoir bottle.
Should I be concerned about introducing air into the system using this method ? Obviously I have to make sure the MC does not get low and pull air.
Old Mar 7, 2016 | 11:33 AM
smithbrl's Avatar
smithbrl
I got some SpeedBleeders. I pulled the maxi fuse. Then I pumped the lever/pedal and kept the master cylinders from going empty. I ran a bottle through the front, first left side then right. Then I ran a bottle through the rear. Reinstalled maxi fuse and took the bike for a ride.
The brakes worked fine. I slowed the bike down in a parking lot and slammed on brakes causing the ABS to kick in a few times front and rear.
Brakes worked fine, no air in the system. I change the fluid every two years, three last time. I let the dealer do the first two times because I was a little worried about doing it myself. Also, I didn't want to spend the $200 or so again.
I'll be doing it myself every 2 years now.
Old Mar 7, 2016 | 02:20 PM
Buelligan666's Avatar
Buelligan666
How do you get the fluid out of the calipers? Sounds like that method would flush the abs system and lines, but you'd still have the old fluid in the calipers.
Old Mar 7, 2016 | 03:03 PM
TheGrandPoohBah's Avatar
TheGrandPoohBah
I used a mity vac on my bike with ABS, keeping the MC topped off, no issue.
As stated, don't get any air in the system and take your time.
Old Mar 7, 2016 | 04:03 PM
BB59's Avatar
BB59
Vacuum bleeding with a pneumatic brake fluid bleeder is by far the easiest and cleanest way to get the job done. Harbor frieght sells one cheap that works perfectly. Hook it up to your compressor, push the fitting onto your bleeder screw, pull the trigger and crack the bleeder screw. Just keep the reservoir full as it draw fluid throught the system. Tighten the bleeder screw pull off the fitting and your done. The vacuum will draw all the fluid into the container and you shouldnt even spill a drop.
On ABS brakes just make sure you dont turn the ignition on and you will be fine. I have 148,000 on my '08 RK and have done this dozens of times. I have never needed to have the dealer bleed my ABS brakes.
Here is a link to a you tube video of it being used on a car but the process is the same
Old Mar 7, 2016 | 07:07 PM
smithbrl's Avatar
smithbrl
The speedbleeders replace the OEM bleeder valves on the calipers so the brake fluid bleeds out through them as I squeeze the brake lever and push the brake pedal and the new brake fluid takes it's place.
Old Mar 7, 2016 | 07:34 PM
TUCCI's Avatar
TUCCI
Nah, when I put apes on my anniversary FXDC I completely flushed the fluid and as long as you don't power up the bike you do it the same way regardless. Don't buy into the ABS hype.
Old Mar 7, 2016 | 07:46 PM
btsom's Avatar
btsom
I believe you guys are changing all of the fluid except for what is in the ABS controller. To pump the old fluid out of that requires the Harley computer.
Old Mar 7, 2016 | 07:49 PM
Boomer1143's Avatar
Boomer1143
I'm using a vacuum operated brake bleeder with no problems. I have flushed my brake fluid several times on my bike.(2012 FLHTK) I have done the same for friends with ABS bikes.
You will be just fine doing what you have planned.
Old Mar 7, 2016 | 09:27 PM
Buelligan666
The bleeder is on top of the banjo where the brake line attaches. There's a fairly large reservoir of fluid down in behind the pistons. When you force fluid into the caliper it's going to enter through the opening in the line/fitting, then take the path of least resistance, which is straight out through the bleeder. I don't believe you are actually flushing the fluid out of the caliper. I don't know that a vacuum type bleeder would necessarily do any better at pulling that old fluid out of the caliper either. It would be effective if the line attached at a low point on the caliper, and bleeder was at the highest point on the caliper. Unfortunately that's not how the caliper is designed. I'm 6 hrs from my service manual, and I've never read what Harley's procedure for this consists of. I'm not sure of the best way to get all of the fluid out, but I think if you pushed the pistons in and forced a lot of the fluid out of the caliper, held the pistons in the compressed position, then bled the system, it would be a more effective way of exchanging most of the fluid in the system.
