Slip on and retuning
Old Mar 11, 2016 | 06:40 PM
mayhem912's Avatar
mayhem912
Default Slip on and retuning
Good evening all. I was thinking about pulling the trigger on a set of fuelmoto hi rollers slip ons. My question is : will I need to retune my bike, or is it OK to put on mufflers without retuning. I'm currently running Vance and Hines tapered slip ons, dresser duals, and hi flow air cleaner. I had the dealer do a flash tuning when I did the exhaust.
Thanks
Old Mar 11, 2016 | 07:00 PM
slapshot12's Avatar
slapshot12
I wouldn't think by swapping only mufflers that you'd need to change your current flash. Call FuelMoto and talk to Jamie. He helped me decide on my stage 1 set up. I got the FM dyno tuned slip ons and micro tuner from him yesterday to go with my HD stage 1 air cleaner.
Old Mar 11, 2016 | 11:02 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
You'll be just fine, leave everything alone and ride it.
Old Mar 11, 2016 | 11:08 PM
heritageblue2013's Avatar
heritageblue2013
Is it fair to say that a dealer flash is nothing more then a scam? Can dealers actually add more fuel with this "flash"?
Old Mar 12, 2016 | 12:32 AM
GroovusMagnus's Avatar
GroovusMagnus
I'm no expert, but that's my opinion. It's a quick couple hundred bucks that does nothing.
GM
Old Mar 12, 2016 | 05:45 AM
RevBlk's Avatar
RevBlk
EPA violation for dealer to change the A/F ratio. So no they do not add more fuel during the Stage 1 download. They adjust the timing and change the Rev Limiter to 6200 rpm. Or so I've been told my a long time dealer technician.
Old Mar 12, 2016 | 08:36 AM
2kids3pets's Avatar
2kids3pets
If you're just changing the mufflers no tune is required.
Old Mar 12, 2016 | 09:43 AM
oakmossy's Avatar
oakmossy
the key to changing exhaust systems is if the engine pops on decel, its running too lean so you need a tune. So you can change the mufflers and if it runs badly and/or pops on decel ( too lean ) you need a tune.
Old Mar 12, 2016 | 10:02 AM
ericl's Avatar
ericl
yep, if it doesn't run right you need to retune. Obviously the dealer was able to change the AFR on his first go round with a canned map.
Old Mar 12, 2016 | 10:53 AM
Bingee's Avatar
Bingee
Not always. The A/F ratio can be changed providing it does not cause street bike emissions to exceed EPA limits. That's why a flash from the factory is required to control any increase in fuel flow by a dealer shop and preserve the emissions compliance warranty. Some stage 1 downloads do in fact increase the fuel flow. But not always to the degree needed.
