Apes
Old Mar 12, 2016 | 08:26 PM
brawner11's Avatar
brawner11
Default Apes
What is the biggest bars i can go without changing everything on 12 street glide?
Old Mar 12, 2016 | 08:35 PM
Mirnldi@gmail.com's Avatar
Mirnldi@gmail.com
I just put 10s on my 13 limited. I think that's as high as you can go with stock cables and wiring
Old Mar 12, 2016 | 08:40 PM
brawner11's Avatar
brawner11
Ok thanksyou
Old Mar 12, 2016 | 10:06 PM
decencyxdefied's Avatar
decencyxdefied
I put 13s on my neighbors 11 cvo rg and didn't have to change cables
Old Mar 12, 2016 | 10:38 PM
RideFree1267's Avatar
RideFree1267
I put 10" Khrome Werks bagger bobber apes on my 2012 and didn't change nothing. My clutch cable is tight. The dealer told me that if I would have gone any taller I would have needed a clutch cable. My 10's are at the top of my fairing.
Old Mar 13, 2016 | 05:49 AM
lizard86's Avatar
lizard86
Height measurements vary from one brand of bar to another. Not all are created equal. Generally if you are going 12 or above you will need to replace the clutch and brake cable. You may get by with the stock cables with some 12s by rerouting the cables but it will be extremely tight.
Old Mar 13, 2016 | 06:13 AM
chrisg81983's Avatar
chrisg81983
What he said.......
I went plus 4 on clutch and brake and 10 on wires Being OCD I definitely was not cool with having to reroute lines to make it all work. I always like to have slack in wiring to ensure there is no tension on plug ends as well.
Old Mar 13, 2016 | 06:28 AM
HKMark23's Avatar
HKMark23
Just an opinion worth as much as it costs but I'd get whatever Apes suited my bike and riding style and then fit whatever cables and harness it took to make em work. If it was necessary to hold off for a time in order to accumulate the necessary $$, thats what I'd do.
Old Mar 13, 2016 | 07:39 AM
grbrown's Avatar
grbrown
Thumbs up
Wise words! I've found that assurances on ther internet are not always reliable, there being no substitute for finding out first-hand and doing things that you will be happy with.
Old Mar 13, 2016 | 08:33 AM
Beaux's Avatar
Beaux
Not all bars are alike .............. one brands 10" does not equate to the same need for another brand. That said, I put 10" WO578's on a 12' Limited. All I added/required were poly bushings and +6 cable (definitely could have got away with +4). I say approximately 10" bars is the max ....
RG's are a different animal, irrelevant to this thread ......................
