I want more power 02 Road King
Old Mar 14, 2016 | 09:49 AM
grbrown's Avatar
grbrown
I have a Supertrapp 2-into-1 and don't have a dip like that, indeed no dip at all. What you have there is criminal! If Thunderheaders are known for doing that then ditch it. Also don't go searching for outright power monsters, get something sensible, like a Supermegs. A decent system should fill in that dip and give you around 90TQ where you are currently getting less than 70TQ. A change of cams is also a great idea IMHO, which should lift the entire torque curve a decent amount.
Old Mar 14, 2016 | 12:22 PM
mike_oh's Avatar
mike_oh
Originally Posted by BB59
As was said earlier your Thunder Header makes good power, as good or better than the Fat Cat which lists for close to $1000. I would also agree with what others have said that a good tune might be the answer to your lag in power at low RPMs. If, however, you have your mind set on dropping some cash into your motor then I think the best bang for your buck would be to have your heads worked over and then get a good tune. Bigger valves, porting and even having your heads decked a bit to raise your compression would provide some significant gains in power. You already have a pretty solid build. Head work is really all that is missing. If you want to go the quick and easy route you could exchange your heads for a set of Fuel Moto's Level B CNC heads for $879. Throw a another $300 or $400 into a good tune and you would be good to go.
This is good advice. Before I did my 117" I too had the 95" with Andrews 510 cams, which I would not recommend, but I had the heads done by Dan Vance. http://www.danvanceracing.com/ He installed bigger valves and ported and flowed the heads. I wound up with 95hp/102tq on my 03. take a look at his page as he has been doing work for a long time and his prices are reasonable. Call him and let him know what you want to do and he will guide you. And that 02 is a rock solid platform engine wise!
Old Mar 14, 2016 | 12:25 PM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Originally Posted by 76FLH
I'm happy with the way she runs on the top end, but I would like a little more in the lower RPM range.
The current set up is, 95 CI, 203 cams, a Thunderheader and a Power Commander lllr (It's an old build). K&N Air Filter. It runs like a bat out of hell from about 65 MPH up, but it has a BIG dip at 2500RPM.
This is what I am thinking:
Power Commander V with Auto Tune
D&D Fatcat ( What baffle should I chose?)
Maybe change the Cam to???
I have done the SE Cam Plate upgrade.
What can I expect from these changes?
Thanks,
76FLH (still have it)
Bore to 98"
10.0 cr
Andrews 57 cams
Our Stage II Torquemaster Heads.
Smooth, reliable, fun.
Scott
Old Mar 14, 2016 | 06:09 PM
ropin4gold's Avatar
ropin4gold
Changing the pulley will give you the most bang for the buck as far as ride ability goes but it is a pain in the *** to do.
Old Mar 15, 2016 | 02:25 AM
pounder35's Avatar
pounder35
Thanks,
I had the same set up when I first bought my bike
First thing I did was change the cam to Andrews 37 and to dial in the Theader was to bend the tabs inside the end of the pipe.... Bend them up a lil and what a difference
That Andrews 37 in a 95 kit is a great combo
gipper
Nov 16, 2023 11:53 AM
Busterbrown
Jan 25, 2014 09:08 AM
deerslayer1543
Jul 23, 2012 02:29 PM
bowlerwa
Oct 10, 2010 09:34 PM
parrothead306
Exhaust System Topics
Apr 6, 2009 10:43 AM
