Starter Issue
Old Mar 15, 2016 | 07:28 PM
hunt4's Avatar
hunt4
Stage IV
Question Starter Issue
I have a 2009 Road King Classic. When I start the bike sometimes it sounds like the starter drops off and grinds, and sometimes it starts fine. I've had it to the dealer twice and they tell me everything I'd ok. I have a new battery in it and keep it on a trickle charger. Not sure what's going on? Need some help.
Old Mar 15, 2016 | 07:35 PM
SBates08's Avatar
SBates08
Your dealer is feeding you a load of bull.
https://www.hdforums.com/forum/touri...-on-09-sg.html
Old Mar 15, 2016 | 07:36 PM
Keithhu's Avatar
Keithhu
Welcome to the forum. Here's where you should start:
https://www.google.com/#q=compensato...e:hdforums.com
Old Mar 15, 2016 | 08:52 PM
hunt4's Avatar
hunt4
Stage IV
Thanks for the info I will start looking.
Old Mar 15, 2016 | 10:44 PM
vicsponjr's Avatar
vicsponjr
Don't know what you mean by dropping off but I think I got an idea about the grinding. My 08 was grinding on start up, but not all the time. Once in a while. I ordered and installed an all-***** starter clutch. wasn't sure what I was doing but everyone was saying it wasn't too hard. "Once you get the parts in hand you'll know what to do" The job was pretty simple and it solved the problem.
Not sure if the compensator caused it to go or not. My compensator did feel weak, judging by slowly letting the clutch out while holding on to the brake. It would bang/clunk pretty good. Would also bang/clunk at low rpm take offs. I planned to change it out over the winter but my stator went before the end of the season. I had a local do the stator and he checked the compensator and said it looked fine. After he put it back together it felt much better. Maybe the comp. bolts were backed out a little??
Anyway, that thread that SBates08 gave you is a good start.
Good Luck
Old Mar 20, 2016 | 05:49 PM
leachman's Avatar
leachman
check the connection of the starter. I had the same happen to me and come to find out my starter was loose and not making the ground connection.
Old Mar 21, 2016 | 06:18 PM
hunt4's Avatar
hunt4
Stage IV
Thanks I removed the starter over the weekend took it apart and found nothing out of the ordinary wrong all the teeth seemed to be ok nothing broken or missing. I'm not sure where the compensator is? As was mentioned in another thread. Thanks for the help
Old Mar 21, 2016 | 07:27 PM
Hausguy's Avatar
Hausguy
Some people let off the starter button too soon and can cause problems. Leave it pressed completely until the engine fires up...won't hurt it. When it fires up, the engine speed will (should) disengage the starter.
Old Mar 21, 2016 | 09:23 PM
hunt4's Avatar
hunt4
Stage IV
Ok thanks that's something to remember you do that so much you may not realize that your letting off too early
BlackBettie
Jun 19, 2018 12:59 AM
joey2time
Jul 19, 2015 04:53 PM
Locmoss
Sep 4, 2013 08:56 PM
donzo63
Jun 16, 2012 04:52 AM
turbo38sfi
Sep 21, 2008 05:19 PM
