starter going?
Old Jun 15, 2012 | 09:37 PM
donzo63's Avatar
donzo63
Stage III
Default starter going?
I have a 2006 ultra classic, just got it recently, and notice when I start the bike the starter starts to crank then goes silent for a sencond then cranks again and starts bike.
Is this normal or is my starter going?
Donzo63
Old Jun 15, 2012 | 09:41 PM
glide2meetu's Avatar
glide2meetu
Welcome to the forum! Not normal. Could be the starter. What mods are on the bike? They come into play if you have had engine work done...
Could also be a weak battery... check that first.
Old Jun 15, 2012 | 09:54 PM
donzo63's Avatar
donzo63
Stage III
Thanks Glide
you may be correct when bike is running display is at 14 volts.
but only at 10 prior to starting and obviously drops lower when starter kicks in.
thanks again I'll try that
Donzo
Old Jun 15, 2012 | 11:54 PM
2AMGuy's Avatar
2AMGuy
Community Influencer
More than likely it's the battery.
I've noticed that my voltmeter reads just above 10 before I try starting it and then it drops below 10.
I installed the battery in March 2010 and it stays on a BT during the cold months and if I'm not going to be riding it for a week or more.
I've been told that it may crank over but not start if the voltmeter is below 10 but I've not (nor ever plan to) let that happen.
Old Jun 16, 2012 | 04:52 AM
Harley Tim's Avatar
Harley Tim
No that's not normal. Disconnect your battery. Take a small stainless steel or brass wire brush to your battery terminals and cable lugs, put a little grease on them, and try it again. Most likely, it's dirty terminals, next would be the battery. However, low volts equals high amps. So, if you continue to use with this condition, it could damage your starter/other elect. components.
Hope this helps....
Best wishes....Tim(HT)
bg3075
Dec 20, 2014 07:23 AM
Damien Bessent
Nov 8, 2014 07:26 PM
Locmoss
Sep 4, 2013 08:56 PM
TimLScheffer
Sep 3, 2013 09:48 AM
Mar 26, 2012 06:54 PM
