There are a few rear stabilizers out there to help with the problem some have.
Have you experienced the wag or sway these fix?
I have personally not had this problem with mine , maybe it's because I don't drive fast enough or hard enough to get it started.
Here's a couple others. http://www.ridestr8.com/ http://www.bikernet.com/garage/truetrack.asp
If I run into this problem , I'll probably check out the truetrack , looks like a nice unit.
Mick
Thanks for the info and the 2 links. The link on the Truetrack was very informative. I haven't experienced the high speed wobble or wagyet either but have talked to those who have. Kind of a preventive step in case this was ever to occur.
