Possible o2 sensor issue
Old Apr 9, 2016 | 11:27 AM
  #71
lp's Avatar
lp
Originally Posted by bdtaylor1979
Apparently the cleaners didn't do anything for the o2 sensor codes. I got gas again and went home and hooked the fuelpak back up. Went for a ride and both the po132 and po152 for both o2 sensors reading high came back. I guess I get to buy another tuner
Yep. Sorry to hear, but I figured.
Old Apr 9, 2016 | 11:45 AM
  #72
bdtaylor1979's Avatar
bdtaylor1979
Yeah, that's ok. Do you have a tuner and if so, what kind? I saw lastnight that vance and hines is making the FP3 for 2007-2013 bikes now. I wonder if that would be better than the inline fuelpak?
Old Apr 9, 2016 | 12:00 PM
  #73
hattitude's Avatar
hattitude
Well at least the cleaners didn't hurt anything, they were overdue for the O2 sensors anyway..... just consider it a maintenance exercise..
But it certainly looks like a faulty tuning device....
I personally am not a fan of piggyback style devices..... If you plan on any other mods along the way, or it fits your budget, I'd go with the DynoJet PowerVision tuner. I use it on both my bikes, and it's a great piece of kit.
If you just want a piggyback device, give FuelMoto a call. I have not used it, but have read good things about their Micro EFI Tuner...
http://www.fuelmotousa.com/p-28236-f...efi-tuner.html
Good luck whichever way you decide to go... at least you now know what the issue was...
Old Apr 9, 2016 | 12:12 PM
  #74
bdtaylor1979
Default Possible o2 sensor issue
Thanks for the info. Thr cleaners definitely didnt hurt. I don't plan on doing any other performance mods other than the exhaust and intake. If I can find a good deal on another tuner, I will get one as long as it doesn't make codes come up lol. I don't know what the difference between piggyback tuners and other ones. So I'm not sure what the pros and cons are of each. I will check out FuelMoto.
Old Apr 9, 2016 | 03:35 PM
  #75
hattitude's Avatar
hattitude
In very simple terms:
Piggyback devices are attached to the ECM and stay connected to the bike. They manipulate (in some cases imitate) signals from the O2 sensors to the ECM. It fools the ECM into running richer/leaner as called for by the device.
A tuner will flash the ECM with a new tune. It actually changes the map in the ECM. It allows the rest of the system to function as designed. The tuner can be removed from the bike after flashing the ECM, or some can stay attached as a secondary set of gauges.
I use and am most familiar with the DynoJet PowerVision tuner. It will not only flash a new tune to the ECM, it will allow for an auto tune process, using the OEM narrow band O2 sensors, to further dial in the flashed tune. It can also be left attached as a gauge. If you get it from FuelMoto, you will get lifetime map support from FuelMoto AND DynoJet. If you ever get another bike, or switch bikes, for the cost of a dealer download ($199) you can get another license for the PowerVision and then use it on the second/new bike.
I currently have a PowerVision from FuelMoto, it is attached to both my bikes and two close friend's bikes. That's 4 bikes that I can remap, auto tune, check for codes, and make adjustments to almost any ECM controlled parameter.
Good luck with the project... once finished, it will be worth it... enjoy the ride!
Old Apr 9, 2016 | 03:58 PM
  #76
bdtaylor1979
Ok. Thanks for the explanation. I will look into the power vision.
Old Apr 9, 2016 | 06:58 PM
  #77
harkon's Avatar
harkon
Originally Posted by 1Canuck
ya, after all what they do is tell the ECM that the input orders went through correctly or hey they did not and we need to make a quick correction. better just to cross fingers that the map is perfect and no need to measure the actual results.
why take your finger off the start button after the engine starts?
Okay, so all of the guys running a PCV without auto tune, one of the more popular solutions out there, are wrong.
Before you start calling people out, educate yourself, then come back and contribute positively instead of spewing garbage.
Old Apr 9, 2016 | 07:03 PM
  #78
harkon's Avatar
harkon
This is the fuelpak that goes on my bike. I got it used from the classified section on the forum last year. I don't know if there is a option to eliminate the o2 sensors on my year model or not.
I'm not sure either, but I'm sure an email to V&H would answer it. During work hours they have an online chat that might really help and is easy to use. I have found the help at V&H extremely useful, and they seem to be very knowledgable.
Did you get the map for the FP from the site or did you just tale it as offered and change nothing. If not, let them know what your setup is, might be you can get a better map.
PCVs and before that PCIIIs, and for that matter most of the piggy back solutions run open loop without O2 sensors. I ran my Honda open loop with a PCIII and run my RGU open loop without issue. I have no idea if that applies to your model though.
Old Apr 9, 2016 | 08:06 PM
  #79
1Canuck's Avatar
1Canuck
Harkon,
thanks for your concerns. before you blow steam you should know who you are talking with. I am educated in flash tuners, familiar with fuelers and those that are in between. perhaps you need the education. do some reading and see how many issues became attributed to piggy back tuners. Narrow band O2 sensors have been accepted to feed back up to date information in order that the ecm can make adjustments for the input. piggy back tuners? have a map generically designed very similar to the dealer stage 1 flash. There are no guarantees that a canned map is performing the best for your ride, or that it performs the same on two identical bikes since you are not using the feedback from the O2 to find out. The popular piggyback tuners fooled the ecm into allowing more gas across the board by altering the signal from the O2 or by adding a dummy O2 at the end of the wire to the O2.
BTW, flash tuners are not for everyone because most will not take the time to tune with them and just use them to flash the starting map.
end of rant!
Old Apr 9, 2016 | 10:26 PM
  #80
harkon's Avatar
harkon
Harkon,
end of rant!
Great, then you know that the ECM doesn't run closed loop all of the time anyway. Obviously for the most precise tuning closed loop and a substantial teach time is required. That said, a good map is more than sufficient for the average ride. The OP is in fact running a piggy back tuner, so the rules therein apply. You have a piggy back box applying a richer injection cycle and the ECM using the O2 sensors to lean it out to the insanely lean factory map. Essentially you have 2 systems trying to accomplish conflicting things. I'm not saying that an open loop piggy back tuner is necessarily the best. All I was saying was that when using one, the O2 sensors may not be necessary. I know they are not for my last 2 bikes. And amazingly enough I still know enough to let go of the starter button once the engine fires. Go figure, eh?
It's really funny with EFI and the arguments about a very precise mixture how we ever got by with the simple carburator. Yet we did, and to ones bike blew up.
