Possible o2 sensor issue
Old Apr 9, 2016 | 10:54 PM
  #81
1Canuck's Avatar
1Canuck
Originally Posted by harkon
Great, then you know that the ECM doesn't run closed loop all of the time anyway. actually most base maps do run closed loop in the normal riding area
That said, a good map is more than sufficient for the average ride.
a good map tuned for the bike once flashed will not need the O2 sensors until something changes.
the ECM using the O2 sensors to lean it out to the insanely lean factory map. actually stoich 14.6 is not insanely lean, It is the most efficient burn and best mileage. However it is not the best performance.
And amazingly enough I still know enough to let go of the starter button once the engine fires. Go figure, eh?
It's really funny with EFI and the arguments about a very precise mixture how we ever got by with the simple carburator. Yet we did, and to ones bike blew up.
don't forget points and condenser, vac advance etc. YES, things were much different back then.
Now we have EFI, map based ecm tuning, computer this/that. a whole lot of different challenges. accept the new reality or go retro with the carburetor.
Old Apr 9, 2016 | 11:40 PM
  #82
harkon's Avatar
harkon
yes they do except when accelerating or under any really dynamic condition. That said we are talking about piggy back tuners and most prefer to run open loop
then you get a new map. That's the penalty for running a piggy back tuner, I'm not saying it's perfect or forever. It is what it is.
yeah, maybe insanely lean was overstated. But the 14.6 or 14.7 that's ideal is not ideal for the average internal combustion engine. Temps tend to get excessive. It's clear that a mix when accelerating must be different than that at cruise but generally speaking can be handled sufficiently with an open loop tune. Maybe not to EPA standards, but sufficiently nevertheless.
Well, we were only talking about fueling. No doubt EFI is a great advancement. Not arguing that. My only assertion here is that with a piggy back tuner, specifically the FuelPak LED that the OP has, he may be better off without the O2 sensors in the mix. I was trying to help the OP with his problem, not trying to start a debate over open loop piggy back tuners versus a ECM flash or ECM replacement. O2 sensors connected to the ECM with a FuelPak, at least the one I use, is contradictory and may be better run open loop.
Spend your money on a closed loop solution, your choice, and sure, best performance. For my modest needs, the FP LCD works perfectly.
Old Apr 9, 2016 | 11:47 PM
  #83
1Canuck's Avatar
1Canuck
W
one last comment, did I say I was closed loop in all areas? I am tuned for performance which is some open loop, some timing adjustments, definitely VE adjustments and I let the ECM monitor it all with the O2 sensors.
Yes the flash tuners are the most expensive and hardest to use therefore most people use an add on to improve on stock at a more modest price.
OK, let us end the debate.
Old Apr 10, 2016 | 12:40 AM
  #84
harkon's Avatar
harkon
right, you did not say that, and that wasn't my point. The point was that it doesn't ever have to run closed loop. You want the best performance, and I just want my bike to run right. Seems we both get what we want by different means.
as mentioned, depends on your desired end result.
I never wanted a debate about piggy back fuel managers vs ECM tuners. The point was to let the OP know he may be better off eliminating the O2 sensors with his FuelPak piggy back fuel manager. If you can show that his FuelPak is better with the O2 sensors than without, then feel free. I simply stated that V&H indicated I was better off without the O2 sensors with heir FP-LCD. I suspect the FP-LED is the same from that standpoint.
kch112654
Oct 13, 2018 07:25 AM
dRoblez
General Topics/Tech Tips
Aug 8, 2016 05:43 AM
dRoblez
The Dyno Room
Jun 8, 2016 02:47 PM
RustyCage
Aug 10, 2015 12:21 PM
Deuce55
Sep 23, 2014 07:11 PM
